I have mixed input for go-pro but can ask in TM/TV facebook group or maybe someone has info on that here. One thing I will say is TM will work fine for AOV (audio only vis) with camera if the camera works at all. The VDJ native camera can fail when used as AOV because it is left open on deactivation and the AOV instance moves around and can be reloaded to new instance. When cameras do not work, it can be something simple or it can be because the camera filter does not exist or it is poorly written. These filters are normally provided by the manufacturer and installed when you install the camera software. I always want to know when cameras do not work though in TM though. I actively pursue it. I think go-pro is a strange one and think last I heard on it the manufacture was trying to do something about it so it can work in a wider range of software.
geposted Fri 04 Dec 15 @ 5:47 pm
