So I've recently purchased a PA speaker - Behringer B210D, and I am running this through the Gemini G4v controller using XLR cables. I have changed the config in settings to run with headphones with the G4V as the soundcard, but I am only getting sound from the tweeters - highly frustrating! I have tried several combos, different cables to no avail.. It is driving me mad. does anybody have any suggestions as to why this could be happening? The speakers are new as are the cables.
Many Thanks - The-Hornet
geposted Thu 03 Dec 15 @ 8:57 pm
Does this only happen with VDJ? Did you try plugging some other sound source into your speakers to make sure they're OK?
geposted Thu 03 Dec 15 @ 9:00 pm
basics first, so don't be insulted or take a hissy fit... lol, you checked control settings on both your speakers and mixer/vdj, and have you got all kill switches disabled, obviously this has never happened to me before... rofl.
Try another source of input into your speakers just to make sure you haven't lucked out and got a couple of dodgy speakers, it does happen, you may have just been damn unlucky.
geposted Thu 03 Dec 15 @ 9:26 pm
Be sure the filter is off. Sounds like it could be partially enabled.
geposted Thu 03 Dec 15 @ 9:38 pm
Thanks for input guys, I appreciate it.
I've checked the filter, and any potential cut off switches - yet still only sound coming from the tweeter. At this point I can now only imagine that either the woofer is fecked or there is an internal issue with the G4V its-self... I'm heading to Maplin to grab another speaker to check. fingers crossed its only the speaker!
geposted Fri 04 Dec 15 @ 5:42 pm
It was the speaker, I'm sending that straight back! annoying - I guess I just lucked out on that one. I believe it happened for a reason because me new speaker is bigger/better and has bluetooth. A nice little extra for a pa speaker I guess.
geposted Fri 04 Dec 15 @ 8:21 pm
hang on does the amp have a cross-over switch maybe dip switch?
On second thoughts Active speaker, maybe not.
geposted Fri 04 Dec 15 @ 10:21 pm
