build 2761 restarting in rendom use of 8.1
geposted Thu 31 Dec 15 @ 4:44 pm
Do you mean 2587? Had serious start problems with a recent update, reverted back to a saved copy of 2582 that worked. Will not upgrade until problem is solved.
geposted Thu 31 Dec 15 @ 6:39 pm
Do you use an external HD?
Which video card do you have on this computer?
geposted Thu 31 Dec 15 @ 7:36 pm
No external hd AMD Radeon video card, it started after the update so it must be it I didn't made any change in my laptop...
Win 7
I7 8gb
Win 7
I7 8gb
geposted Fri 01 Jan 16 @ 3:58 am
updated to 2770 and still the same thing...
geposted Fri 08 Jan 16 @ 5:55 pm
We have your crash report and will investigate.
Is this something you can replicate reliably, or does it appear completely random to you?
geposted Fri 08 Jan 16 @ 7:42 pm
most of the time its when i scroll up and down the browser...
geposted Fri 08 Jan 16 @ 8:19 pm
Please help: I have a startup problem with this build. External HD. VDJ wont open, err msg: Startup of 1 is taking a long time. Thanks
geposted Sat 09 Jan 16 @ 1:13 am
Hi
I had problems last night during my gig. It started to sort of pause for a millisecond and its very noticeable.
When I first noticed it, I tried to close all the other windows I have going coz I thought that they were making my laptop processing slower but it kept on happening all night :(
On startup just now, I had a message saying something like "startup is taking longer than usual".
Please let me know if this is an ongoing issue and if I can go back to the previous version that I had no problem before.
Thanks
Thanks
geposted Sat 09 Jan 16 @ 2:40 am
Can you please tell us what is the cause of the problem ?
geposted Tue 12 Jan 16 @ 12:12 am
someone ?
geposted Wed 13 Jan 16 @ 3:52 pm
i went back to 2522 all good now...
geposted Wed 13 Jan 16 @ 5:01 pm
Maube it has something to do with the size of the database. I'm not sure.
I saw it a few times, but I have not seen it in weeks.
I'm on build 2770
I'm on build 2770
geposted Thu 14 Jan 16 @ 10:50 pm
i went back to 2522 and now its ok, they have my crash report i just want to know what is the problem....
geposted Fri 15 Jan 16 @ 4:53 pm
