When doing Analyze VDJ heats up my pc to terminal levels, it wasnt like this before.
geposted Mon 11 Jan 16 @ 7:51 pm
The scan was changed in one of the recent builds. Maybe that has something to do with this.
geposted Mon 11 Jan 16 @ 7:54 pm
Scan now uses all available cores (on machines with more than 2 cores) in order to scan more quickly. This means that the scan will end up much sooner but it may also heat-up your system a little bit. If it heats up a lot this means that your laptop suffers from cooling. If it's an older machine I would check if the heatsinks, fans and ventilation airways are not clogged by dust.
geposted Tue 12 Jan 16 @ 7:10 am
