Hi Phantom,
a very good skin. Is it possible to add the "warning screen for DRM Files" if I record my mix?
I just asked the support if it's changed but they have it in the default skin.
There comes a warning that the recording will stop if I put a DRM file in the player and if I want to continue.
This message is missing in your skin.
Thanks for an answer.
geposted Sat 29 Dec 18 @ 10:18 pm
djfunkyflow wrote :
Hi Phantom,
Pretty sure no skin can do that .. the main program would need a update for that to happen.
geposted Sun 30 Dec 18 @ 1:14 pm
PhantomDeejay wrote :
V3.4 Out!
Hey how do you get it the skin to record I can't find any windows that pop open to set recording like other skins. Plese help me Rod DJ Daddy Mack E- djdaddymack@shaw.ca
geposted Tue 29 Jan 19 @ 6:33 pm
Is there something i had to do to show the number (numeric) of the Cue (for example 1,2,..) on the wave form and not only the mark? (Mac Os Catalina)
geposted Sun 22 Dec 19 @ 9:20 pm
Would be great if this skin gets worked on, the counting bars at the top are missing.
geposted Tue 07 Jan 20 @ 10:11 am
Phantom Deejay question ? i just started using your skin and did some editing to the XML file to change a few things to my liking. so i kinda know my way around your XML file pretty good Except for i can't figure out how to "Uncheck" some of the info that's listed in the "Field" as you see in my picture with all the Fields 1,2,3,4 etc,etc filled up it just looks messy to me with all them fields filled up with all that extra info. so i want to "Hide" & or "Uncheck" some of the info in those Fields 1,2,3 and so on. can you let me know what line # in the XML to change and or how to uncheck certain Field options thanks
 (Small).jpg)
 (Small).jpg)
 (Small).jpg)
geposted Sat 11 Jul 20 @ 3:33 pm
You want to remove things from the skin menu, or from the deck screens ?
The skin menu starts at line #6948
The Deck info entries on the menu start at line #7020
There you can remove <submenu> entries.
However this will NOT change the info displayed on deck screens.
For this you must edit "everything" between lines #2694 and #2868
geposted Mon 13 Jul 20 @ 9:05 am
thanks phantom DJ for the info sir :-)
geposted Tue 14 Jul 20 @ 1:59 am
καλημέρα ! επειδή έψαξα μα δεν το βρήκα , πως μπορώ να προσθέσω το logo μου στα slipmats ?
Ευχαριστώ !!
Ευχαριστώ !!
geposted Thu 20 Jul 23 @ 7:28 am
You need to edit the skin's graphics file.
When you open the file you'll see a white square space that reads "Your Logo Here"
Replace that white area with the graphics of your logo, save the file and replace it inside the skin's zip file.
You should be done.
You should be done.
geposted Thu 20 Jul 23 @ 12:15 pm
Ευχαριστώ πολύ !!
geposted Fri 11 Aug 23 @ 10:36 am
