Topic: Crash using effects, and when you close.
zanardPRO InfinityMember since 2003
The strange thing is when you close VDJ reopen by itself several times ...
Crashes also using effects ..
it happened to you?
geposted Tue 14 Jun 16 @ 6:32 pm
What you are seeing is the crash guard, and it's designed to re open the app immediately and load and play the track exactly at the point the software crashed.
Your crash report indicates an possible issue with the skin (DDJ SX Skin possibly??) that you are currently using. What skin are you using and Please revert to the default and see if you have the same issues,
geposted Tue 14 Jun 16 @ 8:14 pm
Do you get crashes if the default skin is selected ?
geposted Wed 15 Jun 16 @ 11:07 am
Yes crash even with the original skin.
How many problems with this version ....
P.S. I just assembled a much more powerful system, but virtual dj turns bad the waveform is jerky in this version.
My system: I7 6700 z170 16 GB DDR4 Sound Blaster Z ssd Samsung 850 pro evo 256 GB.
geposted Thu 16 Jun 16 @ 5:48 pm
After a reset of the settings now it works better, but the problem remains that when you close VDJ reopen almost all the time.
Thanks.
Zanard.
geposted Sun 19 Jun 16 @ 10:40 am
So, with settings.xml deleted, no controller connected, and when VDJ starts and then try to close, it opens itself again ??
Can you check if the drivers of the video card are updated to the latest version ?
geposted Sun 19 Jun 16 @ 10:59 am
