I'm using a DDJSX and a single Denon 3700 that controls the active deck, so I can switch decks with the SX or make deck 3 or 4 the active deck and control via the 3700 so no biggie. Just sometimes like to just drag a visuals video into deck 3 or 4 and press play in the background whilst using decks 1 and 2 to mix audio tracks, if that makes sense?????
geposted Mon 04 Jul 16 @ 7:10 am
Is there any way to remove the down headphone toolbar to have more browser area?
geposted Fri 08 Jul 16 @ 8:30 am
Possible: yes, but
where to put prelisten, CPU, Record etc?
Complete rebuild for one or two rows makes no sense imO...
geposted Fri 08 Jul 16 @ 9:14 am
Ok thanks for reply, do you know why VDJ did not remember this wave selcìection? Any time I close and reopen VDJ (8.2 b3291) I need to set it again.
geposted Sat 09 Jul 16 @ 4:37 pm
That's on my to-do list ;o)
geposted Sat 09 Jul 16 @ 6:24 pm
@music234
Awesome Skin. I tested and I think this skin is compatible to any Pad Controller but if you don't mind... could you make a skin dedicated to DDJ-SR.
geposted Wed 03 Aug 16 @ 8:23 pm
Thank you for your feedback.
geposted Fri 05 Aug 16 @ 5:16 am
BTW:
Locodog has found a very smart way to customize your controller:
http://www.virtualdj.com/user/locodog/blogs/5441/How_to__Make_A_Pads_Index_Page.html
Now that's what I call the true power of VDJ. Simple to use solution to customize any pad-controller. Yeah!!!
geposted Fri 05 Aug 16 @ 8:39 pm
Working again in progress:
geposted Sat 06 Aug 16 @ 11:53 pm
...and some other things.
Stay tuned ;o)
Stay tuned ;o)
Stay tuned ;o)
Stay tuned ;o)
sweet. i cannot wait.
geposted Sun 14 Aug 16 @ 1:54 am
Added something for the loops:
- visual
- loop-move-buttons
- sampler-record
Loop-move and sample-record only appears if looped ;o)
- visual
- loop-move-buttons
- sampler-record
geposted Sun 14 Aug 16 @ 7:58 am
Added "new" action browser zoom, so this should work if someone mapped this action...
geposted Sun 14 Aug 16 @ 9:07 am
and some other things will come:
hope to finish soon.
Stay tuned ;o)
Stay tuned ;o)
geposted Sun 14 Aug 16 @ 9:43 pm
And something new vor the V-Jockey will come:
Override-buttons; so you can simple force one deck to be on ;o)
geposted Wed 17 Aug 16 @ 3:42 pm
and some new custom buttons will be added:
geposted Fri 19 Aug 16 @ 8:44 pm
OK fellows, update is on the way ;o)
geposted Sat 20 Aug 16 @ 5:07 pm
Liking how you've done the pad colours, better visibility than the standard skin.
geposted Sat 20 Aug 16 @ 5:30 pm
OK, found out how to. Will be fixed soon...
geposted Mon 22 Aug 16 @ 8:15 am
OK, fixed.
Update is waiting for approve ;o)
geposted Mon 22 Aug 16 @ 4:33 pm
