Update is approved.
Thanks @ Admins ;o)
Thanks @ Admins ;o)
geposted Mon 29 Aug 16 @ 4:29 pm
Thanks for the update!
In the right deck I can't select Multi Fx mode, right S & M buttons seems to command left deck.
geposted Mon 29 Aug 16 @ 6:24 pm
I've seen this too late. Sorry, update will follow tonight. Word.
geposted Mon 29 Aug 16 @ 9:13 pm
Okay. Fixed this. Update is wait for approve.
Sorry for this...
Sorry for this...
geposted Mon 29 Aug 16 @ 9:31 pm
and fixed. Thanks@admins ;o)
geposted Tue 30 Aug 16 @ 4:57 am
buenas tengo una duda en el skin en los jog dice para poner el logo de uno, como se puede hacer eso?
thanks
thanks
geposted Fri 02 Sep 16 @ 2:24 pm
Sorry, I don't understand your post. Could someone translate this?
geposted Fri 02 Sep 16 @ 2:54 pm
To put your logo on a jog, you got to edit the png-file (I hope google translation works right).
geposted Fri 02 Sep 16 @ 2:57 pm
Next update is uploaded, this time I added custom knobbs (swap), so you could add filter-resonance or whatever you want.
It will appears by a klick the small dot beside the filter in the mixer-section. Thanks to DJPhaseFour for his suggestion.
geposted Sat 03 Sep 16 @ 7:09 am
Maybe a dot next to gain as a visual to show limiter activity since the vu's don't show postfader output levels with pffx?
Just a suggestion
There's a lot I like about this skin, not too much I need to change to make it perfect for me,
Just a suggestion
geposted Sat 03 Sep 16 @ 1:32 pm
Very good work! Thank you!
geposted Sat 03 Sep 16 @ 5:59 pm
And approved. Thanks again @admins.
geposted Fri 09 Sep 16 @ 6:16 am
super cool!!!
geposted Sun 18 Sep 16 @ 8:23 am
Is that possible to remember or save Multi Fx mode, (every time i open the program the default is single fx)
so i select Multi Fx mode, (S & M buttons) every time. same thing if i hook up my ddj sr controller
geposted Sat 24 Sep 16 @ 5:41 am
I will check this. It's possible, but I'm not sure if this would work with all the factory default mappers.
geposted Mon 26 Sep 16 @ 8:17 am
Both default mappings and default skins use the action effect_3slots_layout to toggle between Single and Multi FX modes, and this is saved across sessions.
geposted Mon 26 Sep 16 @ 3:54 pm
Thanks for the info, I will change this with the next update.
geposted Mon 26 Sep 16 @ 4:48 pm
Thanks A Lot!!!
@djdad
@nusic234
@djdad
@nusic234
geposted Sun 02 Oct 16 @ 7:54 am
@music234
When is the next update? =(
geposted Sat 10 Dec 16 @ 6:26 am
Ups, I missed this. Thanks for the little push ;o)
geposted Sat 10 Dec 16 @ 8:38 am
