Hi
Love the Ask The DJ feature - would it be possible in a future update to add a fourth option to the right click menu for received messages to show the messages on secondary monitors via the video output ?
We use video walls and/or projectors in our venues and it would be great to be able to show messages from the audience on the screens, possible in a ticker tape style
geposted Thu 21 Jul 16 @ 7:02 pm
Hi,
+1 and Pictures.
GK
+1 and Pictures.
GK
geposted Fri 22 Jul 16 @ 6:09 am
there are pluggins for that feature if i am not mistaken.
geposted Tue 30 Aug 16 @ 11:21 pm
Try Telly Media and Telly Visuals, in the plug in section. These versions are free, donations get you the advanced upgraded versions.
geposted Wed 31 Aug 16 @ 7:24 pm
TellyVisuals Plus gives you access to text messaging and social media depending on what you use for the receiver. Currently supported receivers are iWall, IMU, and PushBullet. Adding Twilio at the moment.
iWall, PushBullet, and Twilio can send images so that TV can pick them up. PushBullet and Twilio (in process) support is built into TV Plus. TV Plus contains over 800 colorful emoticons including the emoji emoticons.
If they add features to AskTheDJ to make it usable for this sort of thing and make it available to 3rd parties I will also support that.
geposted Thu 01 Sep 16 @ 12:03 pm
I am using TV & TM with Pushbullet.
Just want to share that it have worked really good and with great support from the start, thank you Don !!!
geposted Thu 01 Sep 16 @ 4:41 pm
Kindly assist am still unable to push my SMS using PushBullet to TellyVissual, Its easy with twitter
geposted Mon 29 Mar 21 @ 6:38 pm
browser_gotofolder "askthedj://" & browser_window 'songs' & browser_scroll 'top' & get_browsed_song 'message' & param_cast 'text' & deck master get_effect_string text 2
for a manual button to show latest Ask The Message on screen...
(can easily be combined with a repeat and check if new messages etc)
geposted Mon 29 Mar 21 @ 7:32 pm
you even can combine texts by using
as well you can miss messages due to system load and VDJ parallel actions
so waiting for browser to end command is good too giving a final script :
result:
Message received from SENDER : MESSAGE_BODDY
param_add `param_add 'get_browsed_song message' 'get_text " :"' ` `param_add 'get_browsed_song from & param_cast text' 'get_text "From : "'` & param_cast text & deck master effect_string text 2
browser_gotofolder 'askthedj://' & browser_window songs & repeat_start wt 100ms -1 & get_text `get_status` & param_contains 'Browsing' ? nothing : repeat_stop wt & param_add `param_add 'get_browsed_song message' 'get_text " : "'` `param_add 'get_browsed_song from & param_cast text' 'get_text "Message received from "'` & param_cast text & deck master effect_string text 2
result:
geposted Mon 29 Mar 21 @ 8:21 pm
