Topic: VDJ8 using MacBook Pro decks slow and juddering
RockyGCPRO InfinityMember since 2016
Hi, having problems VDJ 8 with my MacBook Pro. Every 4 seconds or so, the decks on screen keep slowing down and juddering. It isn't affecting the sound, but is driving me mad. Does anyone know of a fix for this?
Thanks
geposted Tue 23 Aug 16 @ 8:50 pm
NuzzletPRO InfinityMember since 2015
Could It be the skin?
geposted Tue 23 Aug 16 @ 9:07 pm
I don't think so. It doesn't happen on every track, so I'm thinking maybe a loading issue as my drive is so big. Any ideas?
geposted Tue 23 Aug 16 @ 9:18 pm
I think it is related to a graphics issue. Try to run VirtualDJ UN-Maximized. And make sure not to stretch the image. Also, use skins that match the resolution of your screen. Scaling smaller or larger skins to match your screen is stressful on the GPU.
geposted Tue 23 Aug 16 @ 9:26 pm
When looking at the screen, it's actually the wave line that's juddering slightly, which causes a problem when lining up mixes.
I haven't been using 8 for that long (always used 7), so I'm not too sure how to change the skins or resolution on them?
geposted Tue 23 Aug 16 @ 9:49 pm
Is your screen 1080P?
geposted Tue 23 Aug 16 @ 10:09 pm
Just had a look and the resolution is 2880x1880 MacBook Pro Retina display
geposted Thu 25 Aug 16 @ 8:23 pm
V8 skins generally only come in one resolution. [You're talking about a v7 practice]
geposted Thu 25 Aug 16 @ 8:31 pm
