I have tried but I don't know if its possible. Seeing how that I am not using serato there are so many dead buttons on this controller that I would love to put to use for things like turning on video effects and such however, no matter how I try, these buttons WILL NOT MAP! Are these buttons possible to map? VDJ8 does see when I press them, just nothing happens. I have 10 buttons on these thing Id love to be able to map that are not in use
geposted Mon 17 Oct 16 @ 1:37 am
What buttons are those ? How are they named on the controller ?
Is FLIP available in Serato when the SX2 is plugged or is this something that you have purchased extra ?
Reason asking is to see of those Keys are available only when Serato has Flip enabled (similar to Switching sound card when TC is enabled)
geposted Mon 17 Oct 16 @ 1:37 pm
On SX2 there are only 6 buttons unmapped: The 3 flip buttons on each side of the controller.
However, I can remap these buttons just fine here...
Do you save your custom mapper after doing your changes and have you selected it as the device active mapper ?
geposted Mon 17 Oct 16 @ 3:15 pm
Hello everyone any news about remapping the 3 serator flip buttons?
Thanks
Thanks
geposted Tue 20 Jun 17 @ 11:34 am
Thanks
Thanks
Yes. You can remap them just like any other button on the controller
geposted Tue 20 Jun 17 @ 12:12 pm
Check out locodogs Routine addon, and map it. Maybe locodog will assist you.
http://www.virtualdj.com/forums/213688/Addons/Routine.html?search=routine&page=1
geposted Tue 20 Jun 17 @ 2:36 pm
thanks eveyone am going to have a look
geposted Mon 03 Jul 17 @ 11:46 am
I remapped my Serato Flip buttons on my SX2 with no problem at all.
geposted Mon 03 Jul 17 @ 12:43 pm
Is there anynews from Virtualdj to create a FLIP Control on Virtualdj just like Serato? Because FLIP Control is very useful...
geposted Thu 06 Jul 17 @ 4:11 am
There is an addon in the download section called Routine that's inspired by Flip
http://www.virtualdj.com/plugins/index.html?category=effects&search=routine
Here is the thread explaining / discussing it:
http://www.virtualdj.com/forums/213688/addons/Routine.html?page=1
And a video-tutorial for it:
http://www.virtualdj.com/forums/213944/VirtualDJ_Plugins/Video-Tutorial_for_Locodog_s__Routine_.html
Though I'm not sure if you have a licens that lets you use it
geposted Fri 07 Jul 17 @ 10:57 am
