djcel wrote :
Also try to scan the song again on both builds to check if there is a difference of gain in the bpm calculation.
Hello DJCEL,
I have seen no differences in BPM Calculation between the 2 builds,
neither have I noticed any other differences in Gain.
geposted Fri 27 Jan 17 @ 10:42 am
The audio screenshot I need with the card connected so that it doesn't say error at the end.
Preferably with mouse over the card so that it shows the additional information
geposted Fri 27 Jan 17 @ 11:34 am
OK Adion,
this snapshot is exactly how you requested it,
it's from my other Laptop in my studio where I played the songs so I could do the recordings,
both Laptops have the exact same configurations do to the fact that I copy-pasted the V DJ file in the documents.
geposted Fri 27 Jan 17 @ 12:05 pm
Thanks, I do indeed see some distortion in your 3572 recording.
This distortion does not show up in my own recordings however, and so far I haven't been able to find what could have caused that between these 2 builds.
As another test, can you try to do the same test, but record from within virtualdj instead of through the outputs and see if the distortion is still there in these recordings?
Edit: Also, was there any controller connected while doing the test? If so, was the pitch at the center position?
geposted Sat 28 Jan 17 @ 3:48 am
There was no Midi Controller involved between the 2 Laptops, only the Audio Interface (Novation Audiohub).
Everything was centered (flattened) High, Mids and Lows, Pitch, Auto-gain etc. Nothing was out of place.
I'll try recording directly within virtual dj tomorrow and send you the results. Although I think the problem is when the Music comes out of the Master Volume (from digital to analogue).
Just a Clue, something that I noticed yesterday,
when reinstalling Build 3572 from 3409, the "exclesiveAudioAccess" option, although it was activated "Yes", you could easily hear the audio from background applications when you shouldn't. I tried closing and re-opening V DJ, I played a song in it and on purpose, played a another song using another app (Foobar), you could easily hear both songs instead of only hearing the song played from V DJ. This never happened before.
(The Laptop has Windows 10)
A Second small Clue, although on my settings, I want my Sample Rate to be at 44100 Hz, each time I Up-Dated (Reinstall) the Latest versions from the previous ones, although the rest of the settings remain the same, the Sample Rate changes to 48000 Hz, on both Laptops.
This New INFO might be useful to you.
From the recordings you can easily hear that the High Range (Treble) is more elevated than it should be, even compared to Previous Builds.
Thank you for your time, hope I was some help to you.
geposted Sat 28 Jan 17 @ 11:16 am
That's interesting. I have checked my settings and the sample rate is set to 48000 instead of 44100. I thought I had mine set to 44100 originally so maybe one of the recent builds has changed that back.
Not sure if it makes a difference to the sound output to my controller on WASAPI but I will check later.
geposted Sat 28 Jan 17 @ 11:22 am
Hello Kradcliffe,
Having the sample rate at 48000 when your songs are at 44100 doesn't improve Sound Quality, it causes the opposite, it Lowers and sometimes Distorts sound quality.
I see I'm not the only one that noticed this issue.
geposted Sat 28 Jan 17 @ 11:27 am
I'm not really sure where to set my sample rate. I use mostly vobs (about 80%) which are 48000, but some of my music is 44100. My Mixdeck Quad only handles 44100 so I don't really know what setting to use in vdj. I seems to sound OK whichever setting I use but there may be odd songs that don't when you are the other side of the speakers.
geposted Sat 28 Jan 17 @ 12:51 pm
In wasapi shared, the samplerate is the one set in the device's audio settings in Windows, so this will overwrite what you set in vdj.
In exclusive mode it should be what you set in vdj, unless the driver doesn't allow this samplerate.
exclusiveAudioAccess only has effect for wasapi. For asio it's up to the driver. Most don't allow other applications to use the driver at the same time, but this is not a requirement.
For asio, the samplerate you set may or may not be available from the driver. Some asio drivers only allow the samplerate to be Changed from the asio control panel.
geposted Sat 28 Jan 17 @ 1:01 pm
I believe I have also been experiencing this problem. I played at my weekend function last night using 2 XDJ 700's in HID mode, and using a Pioneer DJM 900NXS mixer as the soundcard. I did notice that the sound (midrange and treble especially) appeared to be a lot louder and not as refined as it usually is and I had to reduce the mid & high via the mixer. When I arrived home I checked the settings and I noticed that the sample rate was set to 'Automatic 48000' and I'm sure I had this set to 44100. I fired up my desktop pc which I use with my Numark NS6, checked the sample rate on VDJ, and it was set at 44100.
I'm playing at the same venue again tonight so I will change the sample rate back to 44100 and see how it sounds.
geposted Sat 28 Jan 17 @ 2:32 pm
Hello Toppadon,
please tell us if you notice the same elevated High and Mid Range frequencies after the Gig that you're having at the same Venue, if the Treble is still to loud after changing the Sample Rate back to 44100 Hz, you are probably experiencing the same problem as we are in this Post-Thread.
Wish you the Best for tonight's Event.
geposted Sat 28 Jan 17 @ 3:10 pm
I've tested using a special wav file that has a spoken sequence of 8 numbers (1 through 8) (uses 8 channels for surround sound) - I ran it through different media players. I've noticed differences... VLC fails to pick out "four", Windows Media Player, the "four" is barely audible, Virtual DJ failed to sound "four", Media Player Classic (MPC-HC) worked OK. Try playing your vob files through the MPC-HC (this gets installed with the K-Lite codec packs). I have a hunch that the "four" is on the LFE surround sound sub-woofer channel. Has the user tried to create different types of video file (rather than "vob"), perhaps mp4 would be more appropriate? I purchase commercially available videos and they always seem to be mp4 and are very good quality in virtual DJ.
geposted Sun 29 Jan 17 @ 3:31 pm
@diamond video disco pretty sure i never seen atomix say they support surround sound ... this seems to be way off topic for this thread since it has nothing to do with vob files or surrounds sound
geposted Sun 29 Jan 17 @ 4:24 pm
Ok... it's not about "vobs" then!
geposted Mon 30 Jan 17 @ 6:11 am
have they checked (if using windows) that the "full range" of sound is being sent to the main speakers?
geposted Mon 30 Jan 17 @ 6:23 am
I will have to agree with you on this, surround support is also something that we don't really need to use, it's the Stereo aspect that we're interested in when playing at a Venue.
geposted Mon 30 Jan 17 @ 12:35 pm
Hello diamond video disco,
doesn't the ASIO driver of the Audio Interface that we use Bypass Window's internal sound card and its Configurations ?
When using an External Independent Audio Interface I think that it doesn't rely that much on Window's Sound Configuration.
could be wrong ...
geposted Mon 30 Jan 17 @ 12:41 pm
LFE is the low frequency effect channel. Down mixing from 5.1 to stereo it is indeed normal not to include this channel (according to Dolby recommendations)
The front channels should be full range already and thus be sufficient for a music stereo down mix.
geposted Mon 30 Jan 17 @ 12:50 pm
Try TellyMedia. It uses all channels in the conversion to stereo or plays in surround depending on your audio settings. It is typical though to drop the LFE channel.
geposted Mon 30 Jan 17 @ 1:39 pm
I have to report my success regarding the issues of the wrong soundwaves and CPU overload on my laptop & Hercules RMX.
I just did one step extra this time. And I explain:
I unistall virtualdj and removed that settings.xml file. Then I install that 8.2.3398 old version.
The program boot like it was the first time ever. I had to set all settings from scratch, but the bpm database remained, so I didn't have to scan again all my files. So, what changed this time?
Well, I have disconnect RMX2 this time during the proccess. So, on the first boot, it was laptop's build in audio device only. Then I did all the settings and when I finished, I closed, reboot and reopen virtualdj. Then, I connected RMX2, virtualdj said that new hardware detected and if I wish to use that sound card, I say "yes" and everything seems OK now!
I can't testify about the sound quality (because that pub I had a party is among those average ones) but the CPU overload and the wrong waveforms fixed totally. I'll know about it in 2 weeks, which I have again a gig to a decent club
geposted Mon 30 Jan 17 @ 2:47 pm
