WIN 7 64BIT 4GB RAM T3400 @ 2.17 HZ, IT'S A DINOSAUR BUT IT WORKS PERFECT =)
EXTERNAL HARDRIVE FOR MUSIC AND HEAVY FILES, PC TWEAKED FOR HIGH PERFORMANCE.
I have been having an issue with VDJ and mp3TAG editor. Just prior to VDJ'S latest update, when I would add a cover to mp3tag editor, I could not see it in VDJ...It was not visible in VDJ. If I would try to load it manually in VDJ, it also will not load.
After I just updated to the latest VDJ version...When I load the cover in mp3TAG editor, it continues to be the same issue, can,t be seen inside VDJ. And will not load manually either? What gives, thanks...
But, a few versions before it worked flawless...
geposted Wed 05 Apr 17 @ 9:08 pm
