Topic: Numark DJ2Go2 - Page: 3
Here it is with the GPD Pocket. The ultimate small gig setup you can literally fit in a handbag. It works absolutely perfectly with VDJ, including full HD video out to an external monitor.
The pocket has:
Windows 10
8gb RAM
128gb Samsung SSD
Micro HDMI out
Long lasting battery so you don't need AC power.
1920x1200 Touchscreen
geposted Sat 28 Oct 17 @ 3:56 pm
how long is long lasting?
my tablet gets 2 hrs if i am lucky with windows 10 and VDJ8 running :-(
geposted Sat 28 Oct 17 @ 6:33 pm
7 hours ish.
But if juice runs low you can top up with any phone charger and a USB-C cable
geposted Sat 28 Oct 17 @ 7:35 pm
The pocket has:
Windows 10
8gb RAM
128gb Samsung SSD
Micro HDMI out
Holy crap!! That is awesome!! I've managed to find a few used ones for around 400/450 bucks. Might have to check um out.
geposted Sat 28 Oct 17 @ 9:25 pm
Using them for my gig at the mo with video out. Totally flawless. Wow!
geposted Sat 28 Oct 17 @ 9:38 pm
kradcliffe wrote :
7 hours ish.
nice my tablet you can only use USB or charge single port .. this one has multiple USB ports then ?
sorry for all the questions but i been looking for something ultra portable for trips etc...
geposted Sat 28 Oct 17 @ 11:21 pm
djet123PRO InfinityMember since 2008
Is anyone working on a skin for the DJ2Go2.
geposted Sun 29 Oct 17 @ 3:53 am
Where's all your music stored? Presumably you'd have to use an external HDD too, as the storage on the GPD is minimal?
geposted Sun 29 Oct 17 @ 9:06 am
Really no need - the default skin will be great for it
But if you want the kind of setup shown a few posts above, you may want to look into simple skin to be able to read everything...
I think the skin in the picture may be the Fruit skin
geposted Sun 29 Oct 17 @ 9:11 am
Well it depends on your collection but all my music and videos fit on the 128gb SSD
It has both USB 3 and USB-C ports so you can use hubs for external devices if you want to.
geposted Sun 29 Oct 17 @ 10:09 am
Using it with my Surface 3 and a 64gb micro sd card as my plan B.
geposted Sun 29 Oct 17 @ 9:06 pm
Can the knobs (volume level, cue) be mapped for other functions when holding down the pad mode button? Waiting on mines to arrive trying to see how I will map to control the bass.
geposted Sat 18 Nov 17 @ 5:48 pm
hrdnx wrote :
Does anyone have any suggestions to improve on the wheel?????
(Not touch Sensitive????))
I have this question too!
geposted Tue 02 Jan 18 @ 8:26 pm
mike44PRO InfinityMember since 2010
How is the sound card audio quality?
geposted Wed 03 Jan 18 @ 12:36 am
It's actually very good. I have used it a couple of times in a reasonable sized club for a quick setup and it's perfectly acceptable. Nice and loud too.
Remember you can also use EQ10 as a master effect if you need to tweak the output sound a bit.
Its very very good for the money. Only change I have done to the mapping is to reassign the pitch faders as volume.
geposted Wed 03 Jan 18 @ 12:51 am
Good to know! I have been thinking about buying one but was unsure if it was bedroom quality or gig worthy. I have the first edition (with no built in sound card) which I like alot. Thanks for the info!
geposted Wed 03 Jan 18 @ 1:07 am
i have bought numark dj2go with virtual dj 7 LE
can i upgrade 7 to 8 for free?
geposted Thu 11 Jan 18 @ 10:58 pm
Go to My Account above then My licenses if you see a download for VDJ8 LE on that page then you get a free upgrade if not you do not.
geposted Fri 12 Jan 18 @ 2:07 am
If you want to use VDJ 8, why not buy a license for your DJ2GO? It's the cheapest license available.
geposted Fri 12 Jan 18 @ 5:59 pm
how much ?
geposted Fri 12 Jan 18 @ 8:20 pm
81%
