Topic: Stuttering video in latest update - Page: 4
videoMaxMemory is the setting that tells vdj how much video memory to use.
If you have problems and the value is very big, you could try if it helps to manually lower it to 100 for example.
@kradcliffe
The problem with your file appears to be with deinterlacing. Working on a fix so should be good in next update.
@don
The problem with your file was that it claimed to be 200fps, but in reality frame timing was variable. The glitching with this kind of files will also be fixed in next update
geposted Sun 01 Apr 18 @ 11:48 am
Brilliant, thanks Adion.
geposted Sun 01 Apr 18 @ 12:32 pm
pweldonPRO InfinityMember since 2009
Looking forward to a fix for this both for vob and mpg (mpg2) files.
geposted Sun 01 Apr 18 @ 4:37 pm
Not sure if it's the same thing, but for me on random videos,maybe one every other night, the audio is kind of skipping.
It sounds like DVJ keeps fast forwarding a few milli seconds through the song.
At first I thought it was corruption in my video, but when I check them the next day they work fine.
It's also not the same video each time. All my videos are legal come from Xtendamix or MixMash and I'm fully up to date on Windows 10.
VDJ version is 8.2 b4204 and I have 12gb of memory.
The videos are on the internal hard drive not an external USB one.
geposted Mon 09 Apr 18 @ 7:40 pm
I have had exactly the same thing but it's totally random as you state. Been previously reported.
I play 99 percent video so notice these things.
geposted Tue 10 Apr 18 @ 7:35 am
Uninstall Cortana Windows 10.
geposted Tue 10 Apr 18 @ 6:46 pm
This happens on a Windows 8.1 machine for me.
geposted Tue 10 Apr 18 @ 7:05 pm
djcelPRO InfinityModeratorMember since 2004
Could you test again with BUILD 4251 (2018-04-12) ?
Quote :
-Fix decoding certain interlaced videos and improve timing
-Fix for jumping frames in variable frame rate videos
-Fix green first frame on interlaced videos in sampler and slideshow
geposted Sat 14 Apr 18 @ 7:04 pm
I can't see all of that listed in the changelog - has it been amended?
geposted Mon 16 Apr 18 @ 11:41 am
geposted Mon 16 Apr 18 @ 11:46 am
and they just released b4252... so there's that
geposted Mon 16 Apr 18 @ 11:47 am
I know but the changeling for that build doesn't list:
Both these fixes are from the "-Fix decoding certain interlaced videos and improve timing" item
geposted Mon 16 Apr 18 @ 12:32 pm
Aah ok - thanks!
djcel was posting from the private beta change logs :p
geposted Mon 16 Apr 18 @ 12:35 pm
I didn't know there was such a thing??!
geposted Mon 16 Apr 18 @ 12:51 pm
there isn't
geposted Mon 16 Apr 18 @ 1:33 pm
freppaPRO InfinityMember since 2002
I think I´ve seen him..is this Steph ;)
geposted Mon 16 Apr 18 @ 3:19 pm
wildcountryclub wrote :
there isn't
Thanks for my first laugh of the day.
geposted Mon 16 Apr 18 @ 8:03 pm
Just updated to the latest early access and something seems seriously wrong with vob videos. They look like they are playing at 15 frames per second, but seems quite random. Can't do much testing as I'm in mid gig.... Not doing it on all videos, but these videos were fine in previous builds...
geposted Fri 20 Apr 18 @ 10:42 pm
74%
