Hi Gang,
If I was to try out a skin, is it easy to do so, then revert back to standard if I didn't like it?
Or is it possible without any fuss to use different skins for different occasions?
Do skins only change the look, or do they contain some mapping as well?
Is there a tutorial somewhere that covers all this?
Cheers.
Cheers.
geposted Wed 25 Oct 17 @ 9:24 pm
Kenny Speed wrote :
Hi Gang,
Cheers.
Cheers.
just head to the skins download section and try one out... if you dont like it go to your documents folder/virtual dj/skins and then delete the skin folder simple as that sir... :-)
geposted Thu 26 Oct 17 @ 1:10 am
Ok thanks.
geposted Thu 26 Oct 17 @ 5:28 am
You can download as many skins as you like and switch between them in the VDJ options with a mouse click. There is no need to delete them. You can even make your own, or modify them, although I have neither the time or inclination.
geposted Thu 26 Oct 17 @ 5:59 am
Thanks for that Bigron1.
geposted Thu 26 Oct 17 @ 6:41 am
