Topic: DirectX Failed to Initialize. - Page: 2
Rune (dj-in-norway) wrote :
If you are using an older version of Windows, you must use the 32-bit installer of VirtualDJ (even if your Windows is 64-bit)
To install 32-bit version of VirtualDJ 2020, download here : https://virtualdj.com/download/pc32
(The 64-bit version of VirtualDJ is only for Windows 10)
The installer should know better and tell you and not install it. Not a user problem but a VDJ problem. Also VDJ should do something intelligent rather than something stupid like tell you to hunt down drivers. duh. This it pretty easy stuff to handle correctly.
As far as I know it runs under windows 8 and up. Just looking for DX 11.1. Win7 only partially supports DX 11.1 and uses a different display model so VDJ64 can't run on Win7.
I also reported this when VDJ64 first came out.
geposted Sun 29 Mar 20 @ 9:27 pm
Strange.
On Saturday night I also had this message once.
The next day everything was back to normal.
But it was with the 32bit version in Win7.
It's strange.
It's called the Ghost in the machine
geposted Mon 30 Mar 20 @ 10:02 am
hi guys I found a fix for the direct x error which actually worked for me if you are using a 64 bit windows and vdj shows the direct x and driver error when launched please uninstall and download the 32 bit version of vdj install it it'll run on your 64 bit system without errors it worked for me
geposted Sat 15 Aug 20 @ 9:02 pm
ianguyPRO InfinityMember since 2017
This issue has raised its head again after i have used VDJ 2021 without any issues then suddenly 4 days ago (after a VDJ update!) it has reappeared.
I updated drivers for Direct x, nothing, updated drivers for graphic cards, nothing.
I updated windows 10 and that seemed to fix it, until now.
My windows 10 and all drivers are up to date, I have uninstalled and reinstalled VDJ so there isn't anything i can do to resolve it except use the 32 bit version but, as far as i can see, there are no stems in that version..
This is obviously not an isolated issue so what is the answer?
geposted Sun 10 Jul 22 @ 8:08 pm
Bom dia, havia visto uma instrução do amigo speedy35 que não esta mais aqui no post, devo procurar em algum outro lugar do post?
geposted Mon 11 Jul 22 @ 12:12 pm
Boa tarde, agradeço os posts inseridos, DJDAD, obrigado pelas dicas, meu ultimo procedimento foi desinstalar e instalar novamente a placa de video nividia gforce, aparentemente o problema foi resolvido, ao minimizar e maximizar ou fechar e reabrir o vdj (sem reiniciar o notbook) não esta travando, obrigado a todos.
geposted Mon 11 Jul 22 @ 6:45 pm
Bom dia a todos, infelizmente o vdj voltou a travar apresentando o mesmo erro de directx, alguem conseguiu uma solução para o problema ?
geposted Wed 13 Jul 22 @ 10:49 am
geposted Wed 13 Jul 22 @ 10:50 am
Bom dia a todos, o suporte do vdj me sugeriu o seguinte procedimento:
( CONFIGURAÇÕES-> aba OPÇÕES-> procure a opção: MATHENGINE e mude para desabilitado), com esta configuração aparentemente o vdj não esta travando ao minimizar/maximizar, mas desta forma perdemos a função de retirar Vocal, Bass, Kick, Hihat ou Instru, acredito que não seja a solução do problema pois até um tempo atrás funcionava normalmente sem necessidade desta mudança de configuração.
Caso alguém tenha a solução para o problema agradeceria informar pois utilizo estas funções.
Obrigado a todos.
geposted Thu 14 Jul 22 @ 2:03 pm
Obrigado a todos.
Boa noite, alguém conseguiu a solução para o problema acima sem ter que fazer a alteração na configuração ( CONFIGURAÇÕES-> aba OPÇÕES-> procure a opção: MATHENGINE e mude para desabilitado), onde perdemos as funcionalidades de retirar vocal, hithat e etc.
geposted Tue 19 Jul 22 @ 1:31 am
Obrigado a todos.
Bom dia, notei que o problema acima somente ocorre quando é utilizado a nova skin no modo pró, voltei para o skin Plasmamod que uso para videos e nenhum problema ocorreu de direct x ou travamento, caso alguem tenha o mesmo problema pode testar com a mudança de skin.
geposted Sat 13 Aug 22 @ 12:58 pm
Boa noite a todos, tive um evento no ultimo sábado utilizando o skin que sempre uso e infelizmente durante o evento o vdj travou com o mesmo erro de direct x, esta difícil confiar na utilização do vdj em um evento oficial, alguém conseguiu alguma solução?
geposted Mon 15 Aug 22 @ 9:45 pm
