For reporting any bug, questions or comment related to the latest version of VirtualDJ
(NOTE: VirtualDJ continuously updated, so many older topic on this forum are most probably already fixed in the current build)
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
Topic: POI Actions not working
sjf_apuPRO InfinityMember since 2011
All I need to do is add a automatic point that will "reverse Active" when there is a bad word and then back again to regular play.
please give an example on how to do this!
geposted Thu 08 Mar 18 @ 2:17 am
locodogPRO InfinityModeratorMember since 2013
Look at the manual for the track cleaner.
You don't want reverse you want to used the dump command.
As a poi you want something like this
repeat_start_instant "rsiSwearingDump" 300ms 2 & dump
It might be 2 300ms and you might want to tweak the ms to something longer or shorter.
geposted Thu 08 Mar 18 @ 4:51 am
Thanks for steering me in the right direction. It (Track Cleaner) works better than I was thinking.
Some times having to trim it up to sound just right! I'm still testing out my skills on the POI editing.
Thanks again for the Tips!
Sam
geposted Fri 09 Mar 18 @ 1:59 am
