All I need to do is add a automatic point that will "reverse Active" when there is a bad word and then back again to regular play.
please give an example on how to do this!
geposted Thu 08 Mar 18 @ 2:17 am
Look at the manual for the track cleaner.
You don't want reverse you want to used the dump command.
As a poi you want something like this
repeat_start_instant "rsiSwearingDump" 300ms 2 & dump
It might be 2 300ms and you might want to tweak the ms to something longer or shorter.
geposted Thu 08 Mar 18 @ 4:51 am
Thanks for steering me in the right direction. It (Track Cleaner) works better than I was thinking.
Some times having to trim it up to sound just right! I'm still testing out my skills on the POI editing.
Thanks again for the Tips!
Sam
Sam
geposted Fri 09 Mar 18 @ 1:59 am
