Hello,
Am about to buy the Pro version of Virtual DJ, mainly for VJing purposes.
Am looking for recommendations for a controller. Don't have a massive budget, so am looking for something under £200.
Although I am mainly interested in the VJing side of things, I might also use a controller for DJing too.
Any recommendations gratefully received.
thanks !
thanks !
geposted Mon 09 Apr 18 @ 8:19 am
any controller that is compatible should serve the purpose can't remember any specifically designed for video.
https://www.virtualdj.com/wiki/VirtualDJ8%20Controllers.html
geposted Mon 09 Apr 18 @ 10:25 am
wickedmix wrote :
...can't remember any specifically designed for video.
Actually the 8+ years old "MixVibes VFX CONTROL" that was just added in a recent build is described as good for video mixing when you look it up
I bought one just because it looked fun (and they were almost out of stock)
I can't figure out why it would be especially good for video mixing though...
But it's pretty fun for regular audio mixing :)
geposted Mon 09 Apr 18 @ 10:36 am
I use a very small & cheap controller for karaoke called "DJ2GO" , it works well for the over 5 years!
geposted Tue 19 Jun 18 @ 2:38 pm
Use since 2011 a VMS 2 for Music Mixing in my Mobile disco,the Controller run we by the First day i have buyed,but for Video mixing that is good enough too.
But think you become this to buy only at second hand.
Eventually you find a shop with a new VMS 2
Other is you buy a 4 Channel Controller we the VMS 4.1 or VMS 5 or
VMS4 Traktor = (VMS4.1)have a traktor Sign on Console.
Buy not the Old normal VMS 4 ,thay have not a good soundcard.
VMS 2 Links:
VMS 2 by Videomixing:
https://www.youtube.com/watch?v=3iBh1snqMkI
VMS 2 Side:
https://www.adj.com/vms2
greatings,Dirk
VMS 2 Links:
VMS 2 Side:
greatings,Dirk
geposted Fri 29 Jun 18 @ 3:23 pm
