Hi an someone tell me if it is possible to install VDJ on Asus transformer T101 that works on windows platform or it would be better to go with ipad because I m considering buying one of these two, so which one would be better?
Thanks in advance
Thanks in advance
geposted Wed 18 Apr 18 @ 9:01 pm
VirtualDJ is only available on Microsoft Windows or Apple Mac OSX only.
It is NOT available on an iPad.
There is a remote control App available on IOS or Android, but, the main program, VirtualDJ, can only run on Windows or OSX.
geposted Wed 18 Apr 18 @ 9:34 pm
Ok, so it should be working well on asus, right?
geposted Thu 19 Apr 18 @ 1:35 pm
It's probably one of the lowest spec Windows laptops available, so I wouldn't imagine it will work "well". Adequately maybe ......
geposted Thu 19 Apr 18 @ 1:44 pm
You can install VDJ 7 and VDJ 8 on a Tablet that Run with a Normal Windows Version.
I have install my VDJ 7.4.7 Pro Full and VDJ 8.2 Pro Infinity on a HP Stream 7" Tablet with Windows 8.1 System on it, but that is a VDJ Run in Minimum System for my AA VMS 2 .
Use this Only with Music.
Think you must buy a better Tablet with Maximum System for this,when this soll Run fantastic.
I use this only for Backup.
Use too a Asus Eee PC R101X (Netbook) 10" inch.
Greatings,Dirk
Greatings,Dirk
geposted Thu 19 Apr 18 @ 3:53 pm
