user made sidelists filters don't update live, they're only true when created.
geposted Wed 29 Jun 22 @ 1:25 am
I can understand that. But what I noticed is at bottom of sideview is a place to add shortcut to folders. So I decided to have my "Immediate Compatible" Filter Folder as a shortcut. So this script will actually be for a filter folder.
geposted Wed 29 Jun 22 @ 1:41 am
+1
geposted Wed 29 Jun 22 @ 8:04 pm
the only fields that update from track on deck are; bpm difference & key difference.
any other field would need a filter writing via plugin, or an unreasonable amount of bruteforce to cover every possibility.
Since you didn't get on with 'sticky', I'd say it's not viable currently.
geposted Wed 29 Jun 22 @ 9:13 pm
As it is I have to click on it to update it...and I'm ok with that. I just need the proper script to search the grouping field and collect matches. I have come to understand it doesn't auto update but I'm ok with that.
geposted Wed 29 Jun 22 @ 10:12 pm
+1
geposted Sun 03 Jul 22 @ 2:25 am
Hey, I want to change the fontsize of the cuenames in the wave-window of the skin.
They are so small that I can´t read them when I´m performing on stage.
So I have to go to the skinfile and change maybe just a number, but WHERE?
I´m using the haunting pro touch-skin by Alex RDZ96.
Thanks in advance for any help
(I posted the question in the skin-area, but didn´t get any answer. Next Gig on Saturday...)
geposted Wed 17 Aug 22 @ 2:21 pm
Solved!
In Skinfile there is the panel [panel name="defaultwave4deck"]
there under "Cue" the font can be changed or resized.
geposted Thu 18 Aug 22 @ 11:37 am
Hi! Why not yet add by VirtualDj team scripts about see in a monitor sample time remaining or sample time elapsed, when a sample is playing? i can see only with script sampler_position a sort of “time passage” when a sample is playing :( is there another solution??
thanks
thanks
geposted Tue 20 Sep 22 @ 8:29 am
Is it possible to select a deck by using value of variable?
What I want to do is to select "previous" deck. Here's a naive version
get_deck 1 ? deck 4 select : get_deck 2 ? deck 1 select : get_deck 3 ? deck 2 select : deck 3 select
geposted Tue 20 Sep 22 @ 4:28 pm
Hi, I'll try here.
In the variable I have the text (name of the effect)
How do I change the colorfx effect with this variable?
doesn't work.
It is very impractical to do that
set_var 'DeckColorSelect' "Echo"
filter_selectcolorfx '`get_text "ColorFXSelect"`'
doesn't work.
var_equal 'ColorFXSelect' '`get_text "Cut"`' ?
filter_selectcolorfx "Cut" :
var_equal 'ColorFXSelect' `get_text "Echo"` ?
geposted Thu 22 Sep 22 @ 8:24 am
Mirda Draxal wrote :
Hi, I'll try here.
doesn't work.
doesn't work.
Someone in the FB group answered it
In one combined script for testing:
set_var 'DeckColorFX' "Echo" & param_cast 'DeckColorFX' & filter_selectcolorfx
geposted Thu 22 Sep 22 @ 9:24 am
Thanks, it works.
I didn't notice on FB
geposted Thu 22 Sep 22 @ 6:11 pm
Hi,
I think there is an error when loading the name of the ColorFX effect when setting Filter (it loads as Filter). Please try the following script
filter_selectcolorfx "Filter" &
set 'ColorFXSelect' `filter_label "name"` &
var_list & wait 1000ms &
filter_selectcolorfx "Cut" &
wait 1000ms &
set 'ColorFXSelect' 'ColorFXSelect' &
param_cast 'ColorFXSelect' & filter_selectcolorfx
geposted Sun 25 Sep 22 @ 7:29 pm
hi, i use Sidelist like a Sequencer…and in my Sidelist i have “Sequencer” samples, but any time i open VirtualDj my Sidelist is empty..so when i use a mapped specific play button in my Pioneer DDJ-RZX….i don’t have samples. I would load a “Sequencer” playlist (i have saved my sidelist like a playlist, and it’s name is “Sequencer”) at first play:
Sequencer Play button: browser_window ‘sidelist’ & file_count ‘sideview’ & param_equal 0 ? browser_gotofolder ‘Playlist’ & browser_scroll +1 & get_filename & param_contains ‘Sequencer’ ? sidelist_load & play : browser_scroll +1 : play
but doesn’t work correctly :( can you help me???
geposted Sat 01 Oct 22 @ 3:05 pm
solved: for help everyone:
browser_gotofolder ‘Playlist\Sequencer’ & sidelist_load & play
work! i thinked that browser_gotofolder was only for folders, is for file (Sequencer is a file Sequencer.m3u) directly too 👍
geposted Mon 03 Oct 22 @ 9:45 am
Hi,
wait 1000ms &
Solved. It is better to ask for the current name of the colorfx effect
set 'ColorFXSelect' `filter_selectcolorfx`
This will return the correct name "FILTER"
I still don't understand why when I select the FILTER effect appears as the colorfx name FILTR.
geposted Tue 04 Oct 22 @ 5:08 pm
Perhaps a bug in the language file you use?
geposted Tue 04 Oct 22 @ 5:17 pm
I want to setup the stems padpage to match seratoDJ stem pad setup...
geposted Wed 05 Oct 22 @ 7:53 am
You're right!!
Translation error.
geposted Wed 05 Oct 22 @ 7:17 pm
