Topic: Flickering skin? - Page: 1
So I recently installed the new version of VDJ and out of the blue, the interface starts flickering from the top of the screen. I've done everything your supposed to (reboot, uninstall, reinstall) but it keeps happening. I even updated my video drivers and nothing changes. Any idea what could be causing this?
geposted Sat 09 Jun 18 @ 6:14 pm
geposted Sat 09 Jun 18 @ 8:57 pm
Does it behave like that on every skin?
geposted Sat 09 Jun 18 @ 9:17 pm
Yea, just checked. It doesnt seem as intense in the other skins, but it still flickers.
I have a Toshiba P55-B5162, Running Win10 64bit, 8GB of RAM, Intel i7-4720HQ & AMD Radeon R9M200X with the latest 18.5.2 driver. VDJ Version 8.2 b4291
Whats funny, is I can load a song hit play and its fine. but when I load video and activate the second screen, thats what sets it off.
geposted Sat 09 Jun 18 @ 10:10 pm
Do you have videoforcefullscreen set to 1?
If so, try setting it back to 0
geposted Sun 10 Jun 18 @ 2:22 am
Just checked that....nope. Its set to 0.
geposted Sun 10 Jun 18 @ 5:55 pm
Just curious, do you get any additional errors on your screen (not enough memory, etc...). Having video issues as well, slightly different, but wondering if there is a link as to how the new version addresses video memory.
geposted Sun 10 Jun 18 @ 6:11 pm
Nope... It runs as normal. Players, effects, cues all still run flawlessly just the issue with the flickering. It sucks because the flickering gets so intense, sometimes, that I can't see the waveforms, time, and key info while it's happening.
I was testing it yesterday and a few times I was able to get it to stop temporarily by turning the second screen off & on. But it would still come back eventually.
geposted Mon 11 Jun 18 @ 12:15 pm
So if you think it’s caused by the version of VDJ did you try going back to a previous build?
geposted Mon 11 Jun 18 @ 12:20 pm
I'd be willing to try and roll it back, but im not sure how to go about doing that.
Oh and I tried downloading some new skins from the website to see if maybe the skin file was possibly corrupted, but sadly, no. They flickered just like the default skin.
geposted Tue 12 Jun 18 @ 3:52 am
how are you connecting to the second screen
geposted Thu 14 Jun 18 @ 5:29 am
HDMI.
geposted Thu 14 Jun 18 @ 1:48 pm
have you tried a different wire
geposted Thu 14 Jun 18 @ 6:41 pm
Just download VDJ from either the download icon or from your account area on this very site(because VDJ 2018 is still early access so the previous versio n is still the 'main' download.
I'm surprised people don't seem to keep the software they download, after they've installed it. Especially if you're going to install early access builds, keep a copy of the previous installer. It's not rocket science!
geposted Thu 14 Jun 18 @ 6:51 pm
Its not the cable, because it still flickers whether connected or not. PLUS, the video output is fine. Just the interface is jacked up.
geposted Fri 15 Jun 18 @ 6:10 pm
Oh, and I actually have the latest build of 8.2, NOT the 2018 beta. I never use betas for live performances, you never know what could happen.
geposted Fri 15 Jun 18 @ 6:11 pm
You said that you "recently installed the new version", so I naturally assumed you meant VDJ 2018 because that's the new version.
geposted Fri 15 Jun 18 @ 6:37 pm
OK, so go back to the last version of 8.2 that did work, and see if that fixed the issue. Previous Versions
geposted Fri 15 Jun 18 @ 9:11 pm
Well, guys, i tried EVERYTHING I could think of to make the issue go away:
Rolled back video drivers, installed previous versions of VDJ, installed the new beta and nothing would change the flickering. So i decided to just restore my windows install and start fresh. That did the trick.
Could of been a problem with an update, or conflict with a driver...who knows. All i know is its all better! LOL!
I was already dreading having to setup Serato DJ to get me through my weekly gigs. LOL!
So i guess the lesson here is: when all else fails, restore! LOL
M.R.
geposted Wed 20 Jun 18 @ 1:18 am
Got the exact same problem, only happens after i trigger milkdrop, and goes mad when a tool tip is displayed.
(milkdrops effect string cycles .milk like crazy)
Not my relic machine this time,
HP probook 650, 12GB
Intel HD Graphics 4600
WinPro 10
I'll have a look if theres a driver to update.
geposted Fri 22 Jun 18 @ 7:30 pm
69%
