Topic: Flickering skin? - Page: 2
There was a driver, that didn't fix it. It was me being stupid using milkdrop that i transferred instead of installed.
Hopefully me being dim can help other people out.
geposted Sat 23 Jun 18 @ 6:13 pm
I'm having the skin flickering issue also. I'm on a mid 2012 MacBook Pro. Are there any solutions yet?
geposted Tue 26 Nov 19 @ 4:54 am
Milkdrop was the issue on ours. Just disengage and make sure you have shader selected. The issue seemed to only be with Milkdrop in the background.
geposted Wed 04 Dec 19 @ 9:18 pm
It is happening occasionally on different skins; but it happens every time I right click.
geposted Thu 05 Dec 19 @ 2:01 am
Has anyone try to tweak the videofps & skinfps? From my past experience, I have encountered this & solved.
geposted Thu 05 Dec 19 @ 9:10 am
Was there ever an update or solution for this issue?
geposted Tue 10 Dec 19 @ 1:44 pm
Has anyone found a solution to this yet? My screen still flickers when I right click anywhere on any skin. Thanks in advance.
geposted Thu 30 Jan 20 @ 1:36 pm
Did you try turning experimentalSkinEngine to No, or skinFps to 60?
geposted Thu 30 Jan 20 @ 1:54 pm
Thanks. If I set experimentalSkinEngine to either "Yes" or "No" the screen flickering stops. It only seems o be doing when set to "Auto"
Thanks again
geposted Sat 01 Feb 20 @ 3:53 pm
