Topic: Duplicate Tracks
Is there a way to find Duplicate Tracks in the database?
geposted Wed 13 Jun 18 @ 2:59 pm
geposted Wed 13 Jun 18 @ 3:05 pm
geposted Wed 13 Jun 18 @ 3:16 pm
Awesome thanks !
geposted Wed 13 Jun 18 @ 4:39 pm
I have been using this to find dups and doing some cleaning.
Just a heads up, even if you have a duplicate file (as in FILENAME) but have different COVER ARTs or other stuff in the TAGs (forgot some, but I think different BPM's or anything in the TAGS), it will not show as a duplicate file.
Until now, I occasionally find a duplicate song manually (when I search for it). So while Gigging, if I see a DUP, I put it aside and check it later on.
geposted Wed 13 Jun 18 @ 5:28 pm
@elenesski:
np ;o)
geposted Thu 14 Jun 18 @ 8:52 am
I am literally just 12 hours into testing out VDJ as a potential replacement for Serato. I am curious, is there any clever workarounds in filtering that could work as a broader duplicate check. like the title is the same first n characters?
geposted Wed 14 Nov 18 @ 3:21 pm
Just put * in the browser search to show all files then sort by title for example
geposted Wed 14 Nov 18 @ 4:21 pm
MediaMonkey
geposted Thu 15 Nov 18 @ 5:09 am
You can create a filter folder with action:
title starts with "abc"
It's not quite convenient if you want to check many files, because you have to alter the filter folder query each time.
But for smaller workloads it'll be just fine.
geposted Thu 15 Nov 18 @ 12:34 pm
I want to write a script that will check all the songs in a specific folder to see if they have duplicates any where else in the Database.
I have made a few attempts but I am not getting anywhere. If someone has a suggestion for me. I would greatly appreciate that suggestion/help/advise.
Thanks you!!
geposted Tue 01 Oct 19 @ 8:25 pm
