Forum: Addons
Topic: Pioneer DDJ-RZX Screens - Page: 3
Hi - before I spend a fortune... Do the screens show the video?
Yes, they do
I was nearly tempted - then I realised that you can't use a USB stick on the RZX - I always like having that as a backup...
Guys, please help me, i use virtual dj on my laptop, without a ddj rzx, i have an hercules ccontroller. I installed the skin on virtual dj but when I open it, i can't change my skin interface because there s no buttons for the settings. Please, i need help!!!
just delete the skin in the skin folder :)
("documents/virutaldj/skins")
how to make virtual dj work to my pioneer ddj rzx
How do i get rid of this from my virtual dj! I mean to go back to settings
I had issue after issue with rekordbox and the DDJ-RZX, which I bought when it first came out. I attributed the problems I had to the typical learning curve when buying unfamiliar equipment. I downloaded Virtual DJ and used it with the DDJ-RZX, and every issue I had (freezing screens, computer self-rebooting, (that was embarrassing) display jittering, un-synched lip movements, and many others...completely vanished the very first time I used it. Using Virtual DJ, I missed using the screens on the DDJ-RZX, but after downloading the DDJ-RZX add-on, I've got the screens back. Works perfectly. No more frustrations working with rekordbox...Virtual DJ is awesome and has made my gigs frustration free. Thank-you for this add-on, and a very stable dj program with great options and support!
Good night, friend, I have problems with the skin install_pioneerddjrzxscreens "I'm not sure what else to do, what did you install for the pioneer ddj-rzx?
hola tengo problema con ddj-rzx no sale audio del master ya es windows 10 por q
[quote=djhazproductions]hola tengo problema con ddj-rzx no sale audio del master ya es windows 10 y con windows 8 si trabaja bien a que se deve eso
не показывает списки треков, как натроить на Browser View - Pioneer DDJ-RZX Central Screen
Please post in English, or use the correct forum area for your language.
If you either read this thread or the VDJ Setup Guide, you will find the answer.
no my rzx song only comes out on channel 1 not channel 2 any help is welcome thanks
Hello !
I can't find the skin in Virtual DJ Extension Menu, and I can't direct download it. How I can do ?
It's probably an auto download then. You need to connect your RZX to VDJ.
No auto download, my screens does not work ! Can someone post the files ?
Try reconnect the controller.
The skin is added automatically .. (or should)
Auto download ok after re-install virtual DJ.
Got the zip file for RZX screens but nothing on the screens...
79%
