This is exactly what I was talking about about having it built directly into virtual DJ or having it as an add-on .
Are there any plans to make this so you can import your own work directly into it as at the moment it uses the default skin for the elements. This has way more potential than skin creator . I see this was developed from the same person that created The other skin editor which for me is full of too many problems . Would love to see this developed further ?
geposted Thu 08 Nov 18 @ 10:43 am
there is some talk of that here -> https://www.virtualdj.com/forums/225078/VirtualDJ_Skins/Skin_Creator_-_Beta.html
importing your own work that is.
geposted Thu 08 Nov 18 @ 11:18 am
Thanks for the information but the link you have provided is for different software that is for skin creator not skin builder . It looks easy enough to use but limited to the default skin . Skin builder works within Virtual DJ directly . Again thank you
geposted Thu 08 Nov 18 @ 12:00 pm
