I am using Virtual DJ 7.4 on a rack mount Pioneer MEP-7000 controller with an Asus laptop. I have used this controller and VDJ version on another Asus laptop for events for a few years with no problems. I have retired from my DJ business but am going to provide some music for my 5 year old grand daughter's birthday party. I have another Asus laptop with very low hours I'll be using for the party. It has Virtual DJ 7.4 loaded on it also. Was originally going to use this as a back up to my other lap top but never did.
I'm using the ASUS laptop with VDJ on it, Pioneer MEP-7000 controller and Rane mixer out to PA.
My problem is that I cannot get the music to play from laptop through my controller and mixer. Only plays through laptop speakers. In my VDJ set up screen the sound set up page does not show the Pioneer MEP-7000 in the sound card drop down. My other lap top showed this. The card is built in to the Pioneer controller.
Any ideas would really help.
Thanks.
Thanks.
geposted Sat 24 Nov 18 @ 8:57 pm
It seems the soundcard of the MEP is not installed properly.
Have you tried to install it ?
Also check device manager in Windows if the MEP is found in the list of soundcards and perhaps have a yellow mark on it which indicates not properly working or not installed correct
geposted Sat 24 Nov 18 @ 9:20 pm
Thanks MZ, I'll check. The sound card came installed in the Pioneer player. Thought it would be a simple set up and it's gotten frustrating. Thought those days were over :-)
geposted Sat 24 Nov 18 @ 9:23 pm
Try to install the driver again from https://www.pioneerdj.com/en/support/software/archive/mep-7000/#drivers
geposted Sun 25 Nov 18 @ 12:41 pm
MEP-7000 (SDJC1)
Pioneer MEP7000
Pioneer MEP7000 (SDJC1)
For longer time there gave a download but this is not more there:
http://www.pioneer.eu/de/support/software/MEP-7000/index.html#download_192
https://www.pioneerelectronics.com/PUSA/DJ/CD-DVD-Media-Players/MEP-7000
mep
-7000/#virtual-dj" target="_blank" rel="nofollow">https://www.pioneerdj.com/en/support/software-information/mep-7000/#virtual-dj
Soundconfigin VDJ 6 - 7.4.7:
Input: none
output : external mixer
Soundcard:Pioneer
Channel 1/2 left
Channel 3/4 right
greatings,Dirk
Pioneer MEP7000
mep
Input: none
Soundcard:Pioneer
Channel 1/2 left
Channel 3/4 right
greatings,Dirk
geposted Mon 26 Nov 18 @ 8:47 am
