Topic: Auto mix and request?
DJt5oyHome userMember since 2019
If I’m playing a playlist on auto mix and someone requests a song can I insert a requested song then continue with the playlist? When I attempt to do this the playlist disappears and needs to be reloaded. Thanks
geposted Mon 04 Feb 19 @ 12:43 am
so your saying while your playlist songs are playing in automix your asking can you add a song ? if so yes you can im not really understanding your question
geposted Mon 04 Feb 19 @ 3:32 am
PhilWPRO InfinityMember since 2011
Are you dragging and dropping the new song into the Automix list in the position you want? Or something else?
Note that there is presently an issue dragging and dropping from outside VDJ into VDJ with the 64-bit version. But this will work from the browser to the Automiz window.
geposted Mon 04 Feb 19 @ 4:29 am
When I go to add a song the auto play stops. I would like for the playlist to continue playing while I cue up another song (not in the playlist) onto a different deck.
geposted Mon 04 Feb 19 @ 8:00 pm
How do you add the song?
geposted Tue 05 Feb 19 @ 3:20 am
