Hi I was wondering why when I plug my HD in to my Mac and finish all BPM In Folders and go on line to register it's all fine but the next day I hope up VDJ and io have to re do all my BPM in folders again as I use my Laptop for work and always on internet.. please advise
geposted Thu 07 Feb 19 @ 12:16 am
What are your “read/write” permissions set to??
geposted Thu 07 Feb 19 @ 5:19 am
its a HD that i can play but i cant move anything off my HD or add from mac
geposted Thu 07 Feb 19 @ 10:15 am
As Huey said above check the drive permissions.
geposted Thu 07 Feb 19 @ 10:17 am
It seems that it's a HDD formatted with NTFS then
You need to use a utility like Paragon NTFS in order to be able to write on the drive, or reformat the drive with a file system your MAC can write to.
VirtualDJ needs write access on the drive to create and update it's database.
That's why your BPM don't stay. Because VirtualDJ can't write that info on the database of the drive
geposted Thu 07 Feb 19 @ 10:18 am
thank you , I have sorted it..
can someone let me know that when I play virtual dj on my Mac sometimes the volume cuts out and the program shutters?
geposted Thu 14 Feb 19 @ 2:36 am
VDJ needs to tell you when there is a problem writing a file... there are other things it needs to tell you as well... silly not to and would prevent questions and confusion.
geposted Thu 14 Feb 19 @ 6:06 am
