Forum: Addons
Topic: Traktor Kontrol S4 MK3 - Page: 4
Hey. djdad, is there any updates? Is there any addon you've mentioned?
Wanted to clarify before thinking about buying it. Can I modify midi mapping the same way in VDJ as other controllers?
Does pressing and holding the JOG button and turning the Jog Wheel adjusts tension of your S4 MK3 in VDJ?
djdad wrote :
Ok, will prepare a separate Addon so that you can try it out.
We are not sure yet, but once we managed to enable the screens, the Jog Leds were acting weird, flashing with no reason, some unknown conflict between the software leds and the hardware ones.
Hy Dad .
Have you make a separate with Displays Funktion ?
That I can try this ..
Thanks Dani
Good morning, I would also be interested in working displays, I read that you succeeded, is it possible to have an update? Thank you
A lot of us waiting for the answer, I would be interested to help with integration too.
and another... waiting.
After reading all the entries I come to the conclusion: VDJ will never support the NI Traktor S4 MK3. And getting the controller to 100% in some other way is probably nothing.
It's a shame because it's a very good controller and the VDJ is much better than Traktor.
I came to the same conclusion.
Hey VirtualDJ team can you please please PLEASE do something for the Traktor S4 MK3 so i can use it on you all's platform your platform is 20 times better than Traktor's. I appreciate the quick fix you all did but I know if you all can get this Traktor S4 MK3 fully functional it will make everyone who owns this board extremely satisfied as well as make novice to expert DJs extremely better and happy.
Can you all please do this for the DJing community please.
Dang. I wish I'd read this before opening a Sweetwater credit card and ordering an S4 MK3. Sounds like the add-on to enable screens may be coming soon though? I would definitely prefer that vs jog wheel colors. Hmm, not sure if I should return it or take the chance and wait.
@djdad let me know if you have a patreon or somewhere I can donate!
Firstly, we need contact where it's possible to reach VDJ Engineer. Most of the work with screens is done by Joe Easton, but I don't think he is working with compatibility with other software like VDJ.
Double post
No, since NI has gone out of their way to block other software from supporting the S4mk3, he would probably be fired if he answered any questions from Atomix regarding VDJ support
Regarding a "VDJ engineer", the lead engineer for integration already posted a few times in this thread
I kept my s4 in hopes this would be released soon.. Has anyone heard any word of the screen fix coming?
For me are the wheel colors more important than the screens. So I can see, which player is running and in what position of the counts they are. What can you see on the screens? Cover? Logo? Which effect you are using? Well, for those things it's enough for me to see it in the skin.
The only thing that would be nice are the motor wheels, but that will be never solved.
The only thing I don't understand is that the purchase of the S4 is made dependent on the functionality of the screens and the motor wheels. It has many other functions that are also supported by VDJ. It works reliably and is otherwise completely usable.
I've just purchased the Kontrol S4 MK3 for using it with Virtual DJ and the support is amazing! Thanks for the great work. Of course, haptic feedback and display support would be excellent, but working with this is soo cool, even without it.
user27859260 wrote :
I love SHIFT-JOG to move fast through a record, and edited this mapping to do that.
Just in case this helps anyone, I manually edited the mapping zip to replace
<map value="SHIFT" action="shift" />
with
<map value="SHIFT" action="shift & loop ? wheel_mode 'loop_move' while_pressed : wheel_mode 'search' while_pressed" />
Thanks for your help! If anybody else wants to use it: Instead of editing a zip-file you can use the Controller Editor. Just go to the shift-section and enter the following code:
I prefer to use SHIFT + MOVE Encoder to scroll through the track like in Kontrol S2 MK3. If you like it as well: Just set SHIFT_MOVE_ENC to "beatjump".
can i play with s4mk3 at virtual dj with a pro subscription or i must have a pro infinity subscription ?
the uv leds at master volume dont work , can someone help me
89%
