Forum: Addons
Topic: Traktor Kontrol S4 MK3 - Page: 1
Discussion about Traktor Kontrol S4 MK3
Known issues.
- Screens not working
- Haptic (Motor) Wheel mode not working
- Faders not reporting their positions on start up. To get their positions, move any fader after statup
geposted Sat 23 Feb 19 @ 11:36 am
Hello,
Thanks for the great mapping. :-)
I do not want to jostle, but is there a plan when the display and haptic will work?
I'm just adjusting the mapping for myself and I do not want to do the work twice if there's an update soon.
There is plan for full support, but not anytime soon I'm afraid.
Hello. I have few questions about this controller. First of all, thank you for mapping, it works pretty well, altough i hope to see haptic and screen working in the future). I understand it takes time, but may be you could fix fast at least problem with "faders not reporting their positions on start up"? It's not a big problem, actually, but, when i turn controller on, and load and play any track before i moved any fader, the sound goes right to the master, at max level. One day can happen big confusion on the soundcheck).
Another question is about decks colors - is it possible to change it? I have tried to change led deck color in the mapping, but it change only "deck select" button, not the jog led etc.
Another question about effects - vdj does not save them on decks "C" "D". When i restart vdj, all 3 slots are empty, but it works well with decks "A" and "B".
What do i do to get the mapping to work
download button does not work on my end
Yep that's right, pro licences only.
*Quick edit, I see you've got at subscription now, good choice.
According to the devs, that won't help (it was posted earlier):
"Actually no, he can't help. That guy modifies the way Traktor talks to the screens. He didn't create an app that talks directly to screens. Traktor still does the talking.
To make it "simple", this guy modified the "skin" of the screens. He didn't made a stand alone application that draws elements directly on the screens. And that's the issue here. If you can't draw on the screens by yourself, you can't "skin" them"
That's too bad, I was hoping he has the solution
Known issues.
Hey guys, any updates on the screens/haptic drive? I've had this controller for long enough now and just want them to work with VDJ.
Thanks!
hi, news about screens??
If there's news, it will be announced here, and since there's no announcement there's no news.
I hope the Wheels can spin soon in Virtual DJ.
And Displays are working.
Whats goings to this?
I will work with the Controller soon ;-)
Ich schaue auch jeden Tag hier rein......wenn es das Update gibt, wirst du es bestimmt hören, egal wo du wohnst ;-)
Wahrscheinlich werde ich das , wollte nur nit das es in Vergessenheit gerät ;-)
buongiorno
volevo sapere fra quanto tempo arriverà l'aggiornamento per il controllore traktor s4 mk3
grazie
saluti paolo
Hallo,
klasse Mapping. DANKE!!!
Aber! Ich vermisse das schnelle vor/zurück spulen wenn ich am Turntable drehe.
Wäre schön wenn die Geschwindigkeit mit gedrückter SHIFT Taste höher wäre.
Gruß
Udo
A good better Mapping I have written .
But now I hope thats soon an Update where the Patters can Spin.
And the Displays works.
Than its a perfekt Tool.
21%
