I recently purchased a new VMS5. I downloaded driver Asio 1.25 and downloaded 8 LE with the included code. I followed the instructions for setup but when it came play time I have no audio on deck 2. Can anyone please help me resolve this issue?
geposted Mon 11 Mar 19 @ 6:01 pm
Is your VMS5 set to 8out mode (front switcher) ?
If not..
Power off VMS5, set to 8out , power on VMS5, open VDJ
If not..
geposted Tue 12 Mar 19 @ 2:53 pm
It's set to 8out, still no deck 2 sound. Under audio settings it's External mixer & vms5 soundcard. outputs read as: Deck 1 out 3&4/ Deck 2 out 5&6/ Deck 3 out 1&2/ Deck 4 out 7&8.
geposted Tue 12 Mar 19 @ 8:27 pm
All other Decks (1,3,4) have sound properly ?
You have speakers connected to the Master Output of the VMS5, right ?
In VirtualDJ Settings->AUDIO tab, once the ADJ ASIO is used in audio configuration, there should be an ASIO button below the deck x lines.
Click on that for the ADJ ASIO Utilities window to appear and post a screenshot here.
geposted Tue 12 Mar 19 @ 10:05 pm
Maybe it's a crossfader issue.
What channel is the crossfader assigned to? At the front of your VMS 5?
geposted Wed 13 Mar 19 @ 8:36 am
CF A is set to ch2 and CF B is ch3
geposted Wed 13 Mar 19 @ 2:27 pm
For some reason it's not posting. I'll tell you what it reads.
Mode 8out 2 in
Ch group - midilog1 out 5L out 6R
Midi2 out1L out 2R
Midi3 out 3L out 4R
Midi4 out 7L out 8R
Buffer 6ms
Mode 8out 2 in
Midi2 out1L out 2R
Midi3 out 3L out 4R
Midi4 out 7L out 8R
Buffer 6ms
geposted Wed 13 Mar 19 @ 2:32 pm
I believe it should be like this..
http://www.virtualdj.com/image/93446/195489/Midilogs%208out%20default.png
Make the Edits as the image above, and see if it works now. You may have to restart VDJ and VMS5... not sure if the changes are applied without.
geposted Wed 13 Mar 19 @ 2:44 pm
You can look too in the Installation Manual for VDJ with VMS 5
https://www.virtualdj.com/manuals/hardware/americanaudio/vms5/index.html
VMS works only on this USB Port, where they hang by the Installation.
geposted Wed 13 Mar 19 @ 3:09 pm
When I recently logged on, VDJ did some update and everything works perfect...Thanks for helping me with this everyone. Keep on spinnin'!
geposted Tue 19 Mar 19 @ 4:53 pm
That good news that all now works perfect with the VMS5.
geposted Wed 20 Mar 19 @ 7:48 am
