Forum: VirtualDJ Plugins
Topic: Question @kaleo
Hi,
is it possible to make a crossover plugin wich cross-over not by time (like virtualdj does) but at a volume level from the tracks. (Like the crossover Plugin from Winamp)
Example:
Deck 1 music plays. At the end of the song at -30 db or -40 db (could be set) level the crossfader turns to deck 2.
That would be great if you use virtualdj at a party with automix. So you have very good crossovers.
greetz
Janosch
geposted Thu 30 Oct 03 @ 7:01 am
kaleoPRO InfinityMember since 2003
Yes, it may be possible but you will have to start this plug_in on each deck.
I will look at this.
geposted Thu 30 Oct 03 @ 9:06 am
Hi,
yes very good. Would be great if you could make one.
Thanks a lot
Janosch
geposted Fri 31 Oct 03 @ 9:58 am
Janosch: I don't find a clean way to do this and with the new 1.07b version, I'm not sure it still usefull. Isn't it?
geposted Wed 19 Nov 03 @ 8:59 am
