If 2 video effects that use VDJFLAG_VIDEO_OUTPUTRESOLUTION are active on same deck as a video, when the video plays there is bad flicker. For example, make text and slideshow active on deck 1 with a video on deck 1... play the video... Text effect must have text to draw
If a video effect that uses VDJFLAG_VIDEO_OUTPUTRESOLUTION and is active and when there are videos on decks 1 and 2 and there is a transition, the transition will change incorrectly.
geposted Sat 18 May 19 @ 7:33 am
I have noticed this for a couple of updates now, and I can see that it does this when I play the file, not paused.
Thought it was graphic card problem, but now I know others have the issue.
The VideoCube effect will also star out of sync (50%) with the X and Y and I have to go into the settings and do a reset on it when startup (not on video).
Link to video: https://youtu.be/Y0HDCdnFZz8
geposted Sat 18 May 19 @ 6:25 pm
