Topic: VJD 64-bit only BUG
BUG:
When dropping an audio file (from windows explorer) onto a deck, it only sometimes loads, but not always on the deck you dropped it on! Most of the time the file doesn't load at all.
geposted Tue 30 Jul 19 @ 9:44 am
are you using the default skin?
geposted Tue 30 Jul 19 @ 10:12 am
PhilWPRO InfinityMember since 2011
Are you running the latest version? There was a problem quite some time ago with drag and drop on 64-bit.
geposted Tue 30 Jul 19 @ 6:13 pm
Hi,
Sorry for the slow reply - I was not getting notifications from this post(?)
I am using the default skin (TWO DECKS) and the latest build. V8.3-64 b5186
It depends where on a deck you drop the file as to what happens...
For example:
- dropping a file on the effect section (left deck) = loads as expected
- dropping a file on or around the jog wheel (left deck) = nothing happens
- dropping a file on the pitch fader (left deck) = loads on right deck!
NOTE: this is ONLY an issue when dragging a media file from a Windows File Explorer window onto a deck.
geposted Thu 08 Aug 19 @ 1:17 pm
I can confirm
after some tests in 6 decks mode:
drop to sideview does not work at all
dropping a file just or around the jog wheel (left deck) = loads on deck 4
after some time only drop to cover artist title still working for left
and only dropping to gain and jog for right deck as well as dropping near left pitch
geposted Thu 08 Aug 19 @ 3:30 pm
Pretty sure you should drop only where the track info is displayed not just anywhere
geposted Thu 08 Aug 19 @ 3:34 pm
on 2 & 4 deck default it's anywhere for that deck
geposted Thu 08 Aug 19 @ 3:47 pm
I am absolutely sure that if you drop a file onto the jog wheel of deck 1 it should load as expected and this behavior should be the same on VDJ 32 and VDJ 64.
geposted Thu 08 Aug 19 @ 9:13 pm
Back home I tested again : Strange enough for a post :
* All in One old PC
And : There is absolutely NO PROBLEM !!!
- dropping to sidelist is working ok
- left drop tracks to left deck
- right drop track to right deck
* Old Laptop :
I can confirm nothing works
same windows 10 1903, same VDJ v8.3-64 b5186 for all 3
the differences : processor Core Duo E6700 + intel internal GPU + 2 full HD displays vs i5 M520 1368x768 & previous post from I5 3470 + internal GPU + NVidia quadro + 2 *1600x900 display on intel
+ Spacedesk virtual Display on all 3 with dedicated wifi device
Core duo PC:
ASIO : ok - Hercules ASIO + aso4all + voicemeeter asio
Wasapi : ok - Realtek & Hercules & USB & BT
Experimental Skin engine : OK
Normal skin engine : OK
Video : NONE
Shader : Ok some fail with BSOD
Virtual display : OK
Controllers : OK
General use :
- doesn't start with some audio configs in xml file - unused & previously working & 32 bit OK
- Random restart /recover changing skin too often
- Some Network freezes
- does not exit cleanly most of the time - network related
I5 M520 & I5 3470 :
ASIO : Hercules working, NONE of Asio4all & voicemeeter
Wasapi : A Pain with Realtek - USB default & Hercules & BT OK - NVidia not working may be too old drivers
Experimental Skin Engine : MANY Bugs i.e.: stack not working - refresh missing
Normal Skin Engine : Render with glitches on resize
Video : OK
Shaders : OK
Virtual Display : A Pain to connect & doesn't stay connected when VDJ scan dervices again
Controllers : OK
General use :
- some random restart /recover
- exits cleanly most of the time
geposted Thu 08 Aug 19 @ 9:14 pm
