I cant delete or move Tracks, both are not working anymore for me and some Other User in German Forum.
VDJ 2018 Buildt 5186 (32bit)
Win10 Pro 64
Extern HDD
Win10 Pro 64
Extern HDD
geposted Thu 15 Aug 19 @ 9:56 am
Win10 Pro 64
Extern HDD
Win10 Pro 64
Extern HDD
Delete works ok for me
VDJ 2018 Build 5186 - 32bit
Win10
geposted Thu 15 Aug 19 @ 12:22 pm
Delete the entry from the database, or delete the file from the hard drive?
geposted Thu 15 Aug 19 @ 4:30 pm
Will Test tomorrow nee.
Delete The Track from Entry of Database
geposted Thu 15 Aug 19 @ 10:05 pm
Check if the current OS user has Write permissions to the VDJ folder and the Hard Drive itself.
geposted Fri 16 Aug 19 @ 6:20 pm
Have Full Permission as Admin in all.
I Go Back to a Early Buildt,and wait For The next Early Access Buildt or Standart Buildt
Thanks in All
Thanks in All
geposted Sun 18 Aug 19 @ 10:45 am
Works for me too.
Have you tried different folder and/or different Hard Drive (if available). Other than Write permissions to the destination folder, i cant think of anything else.
Does it work for you with a previous VDJ Build ?
And just to be clear, are you trying File Operations->Delete or Remove from Search DB ?
geposted Sun 18 Aug 19 @ 11:22 am
With Buildt 5146 all works fine now.
Will Test with Buildt 5186 next time ,when a new Early Access ist avaible.
geposted Sun 18 Aug 19 @ 12:45 pm
djdad wrote :
Works for me too.
Different Filder yes,but Not works
Different HDD No,but have many HDD's ans USB Sticks.
Previous Buildt 5146 works fine
File Operations = Delete
We i say when The next Early Access Buildt is coming Out ,i will Test Buildt 5186 for make a Second Test.
Thanks
geposted Sun 18 Aug 19 @ 1:05 pm
