Hi pls I use android phone, I have VDJ remote, it works very well when I connected it.
My question is the Sound I mean the headphone 🎧 there is no way that the headphone volume will pass through the phone so that i can move around small and play it very well.
Thanks.
Thanks.
geposted Fri 30 Aug 19 @ 6:42 pm
No
geposted Fri 30 Aug 19 @ 6:57 pm
If VDJ is used in combination with Voicemeeter you may use try its VBAN feature & VBAN Receptor
NO need to use voicemeeter for everything in VDJ, just add an extra headphone channel using it
enable stream "Stream1" from headphone bus
connect android VBAN Receptor
really don't know if both apk would like to live together
geposted Fri 30 Aug 19 @ 11:52 pm
Pls I have done everything and add another headphone channel but I can't enable the stream and even don't know where to enable it.
Pls help me that
Pls help me that
geposted Sat 31 Aug 19 @ 1:51 pm
What do you will make ?
The VDJ Remote ist only to Work with VDJ Software.
In The Remote Software there Comedy No Tone.
When you will Mix mit VDJ Home Free you Must Use a Buildt in 4.1Soundcard or Mir Channels vor Mixing Master and Preview in Headphone.
geposted Sun 01 Sep 19 @ 11:01 am
