Topic: KEY Lock / Pitch Lock
Evening guys,
Not gigged in a few weeks, just checking everything over for a gig tomorrow and i'm a little confused with the Key and/or Pitch lock.
On previous builds I could raise and lower the Tempo on a track whilst maintaining the same key (no squeaky mouse voices or dying robot voices)
Now it seems there's no option to keep this same lock on... When I increase the tempo the pitch is increasing and vice-versa.
Am I missing something or is it gone for good?
Thanks in advance
geposted Thu 05 Sep 19 @ 4:21 pm
check options/MasterTempo
geposted Thu 05 Sep 19 @ 7:23 pm
Resolved! Thank you.
geposted Fri 06 Sep 19 @ 3:55 am
np ;o)
geposted Fri 06 Sep 19 @ 4:38 am
Dj SixGTPRO SubscriberMember since 2008
Thaaaaaaanks, you did my day...
geposted Sat 15 May 21 @ 5:05 am
Just resolved my issue - many thanks
geposted Thu 19 May 22 @ 9:35 pm
I bought pioneer opus quad.. when i select a song in deck 1 them tempo automatically set to other dekh and sometimes pitch lock..... How to turn of this feature?? I just need to sync manually
geposted Sun 10 Dec 23 @ 2:59 pm
Check out Klaus' awesome videos:
geposted Sun 10 Dec 23 @ 3:02 pm
