Topic: KEY Lock / Pitch Lock
Evening guys,
Not gigged in a few weeks, just checking everything over for a gig tomorrow and i'm a little confused with the Key and/or Pitch lock.
On previous builds I could raise and lower the Tempo on a track whilst maintaining the same key (no squeaky mouse voices or dying robot voices)
Now it seems there's no option to keep this same lock on... When I increase the tempo the pitch is increasing and vice-versa.
Am I missing something or is it gone for good?
Thanks in advance
geposted Thu 05 Sep 19 @ 4:21 pm
check options/MasterTempo
Resolved! Thank you.
np ;o)
Thaaaaaaanks, you did my day...
Just resolved my issue - many thanks
I bought pioneer opus quad.. when i select a song in deck 1 them tempo automatically set to other dekh and sometimes pitch lock..... How to turn of this feature?? I just need to sync manually
Check out Klaus' awesome videos:
