Topic: NEW VERSION: VirtualDJ 2020 - Page: 11
baz727PRO InfinityMember since 2013
VDJ2020 looks great..
But - how do you "offload" a cued track ? Used to be cue button, then right click for 2 seconds.
Doesn't work anymore..
geposted Sat 12 Oct 19 @ 12:37 pm
geposted Sat 12 Oct 19 @ 1:21 pm
Thanks for that Groovin'
Only in Pro though - strange !
geposted Sat 12 Oct 19 @ 2:39 pm
No, it's in Performance too. It does disappear if you enable video though. :-/
You could always stick it on a custom button or pad (except in Starter view). Also you can still use old skins.
TBH I could never understand why a DJ would need a deck to be empty. Surely it's better when DJing to always have something ready to play.
geposted Sat 12 Oct 19 @ 2:56 pm
Agreed - but if you want to use Automix it will initially play the track that is pre-loaded before the Automix selection...
geposted Sat 12 Oct 19 @ 3:54 pm
Ah well I'm a "real DJ" - I don't use automix. :-)
geposted Sat 12 Oct 19 @ 4:13 pm
Stamat B wrote :
Djratedxxx this skin is brilliant!
Not a working skin. An idea I would like. This is a picture edit. Can you make it from the default skin?
geposted Sat 12 Oct 19 @ 7:18 pm
You must have a bladder the size of a cow !!
geposted Sun 13 Oct 19 @ 3:42 pm
No, I just prepare beforehand. I try to avoid leaving my kit unattended while I'm DJing.
geposted Sun 13 Oct 19 @ 3:55 pm
geposted Sun 13 Oct 19 @ 6:04 pm
GalawasPRO InfinityMember since 2013
LordWanhoop wrote :
Galawas wrote :
Hi, I have a problem with the FX & Pads panel view options on the default skin, they reset whenever you switch to another skin and back. Is there a way to save these?
Here the same after every restart of the program in the Pro-skin
[UPDATE:] Submitted a ticket about this...
Galawas
Hi, I've noticed when I change from the default 2020 skin to another skin and back, the "Effects" & "Pads" Toggle options both reset to their original default settings. Is there any way to save these settings?
Wed 02 Oct 19 @ 4:15 pm
Official Teamer
Hi,
i'm so sorry but this is currently not possible.
Please create here a new topic with your request.
http://www.virtualdj.com/forums/18/Wishes_and_new_features.html
Kind regards
VirtualDJ Support Team
ATOMIX PRODUCTIONS
geposted Tue 15 Oct 19 @ 10:29 pm
Updated last night.
geposted Wed 16 Oct 19 @ 11:07 am
Oh wow, that’s a big one 😀
geposted Wed 16 Oct 19 @ 11:55 am
geposted Wed 16 Oct 19 @ 1:27 pm
Not now at the moment but probably will be soon!
geposted Wed 16 Oct 19 @ 2:48 pm
LIMOLPRO InfinityMember since 2003
Hello
the minimize button
reduce virtualdj in the taskbar, does not appear on the skin
Starter
Essentiels
Pro
Performance
Windows 10 64bits
VirtualDJ 32bits
geposted Wed 16 Oct 19 @ 7:04 pm
It's working for me here.
VDJ 2020 64 bit on Windows 10 Home with ASUS video card. VDJ setting experimentalSkinEgine = off.
geposted Wed 16 Oct 19 @ 7:37 pm
LIMOL wrote :
Hello
Windows professional 10 (64bits)
VirtualDJ (32bits)
was on auto, on yes the same
minimiser fonctionne, mais c'est le bouton qui n'apparait pas
may be an oversight of the skinner
geposted Wed 16 Oct 19 @ 7:57 pm
Why are you using the 32 bit version if you have a 64 bit OS?
geposted Wed 16 Oct 19 @ 8:22 pm
because I use full effect in (32bits)
not at the moment (64bits)
After the minimize button does not interfere it was just for the reported
geposted Wed 16 Oct 19 @ 8:26 pm
76%
