Topic: VDJ 2020 MC4000 native support troubles!
I updated and all is not well, so I thought I'd report it.
Setup: Denon MC4000 latest firmware 0.17, latest Denon Windows driver 1.0.4
Laptop: Windows 10 i7 16gb, VDJ 2020 b5308
Problem list:
FX ON/OFF 2 and 3 on both decks are no longer mapped properly.
ASIO DOES work but only on USB 2 port. USB 3 port will not connect to MC4000
--I'm open to WASAPI but I can't figure out how to make it VDJ exclusive. 22ms latency is not acceptable for me
geposted Sat 28 Sep 19 @ 5:51 pm
1) Set fx mode to multi
2) When the device is connected on the second USB make sure that Windows are not using it's soundcard as their default playback device
geposted Sat 28 Sep 19 @ 8:31 pm
I just reported that the BPM on jog wheels freezes on both and therefore not displaying correct BPM ongoing music.
geposted Sun 29 Sep 19 @ 12:25 am
hh73PRO InfinityMember since 2006
denon is having issues with most of their controllers and the new builds of windows 10. they know. but dont seem to be doing to much. i think they are focusing a bit too much on prime 4.
geposted Sun 29 Sep 19 @ 11:33 am
I set the fx to multi but the 1st and 3rd fx slider are moving at the same time.
geposted Sun 29 Sep 19 @ 2:37 pm
....and what FX have you got loaded? If the same effect is in slot 1 & slot 3 then you will get both sliders moving.
geposted Sun 29 Sep 19 @ 2:40 pm
Flange echo reverb
geposted Sun 29 Sep 19 @ 5:03 pm
