Topic: Fader are Jumping Skin bug?
metrixPRO InfinityMember since 2007
geposted Sat 19 Oct 19 @ 4:59 pm
I think there's a small gap in the vector graphics, because if I change the background colour on my edited default skin (to red, blue, green etc), then I can see a line the same colour as the background.
....or maybe not. It only happens when experimentalSkinEngine is set to 'yes'.
geposted Sat 19 Oct 19 @ 5:10 pm
DJ FORMATPRO InfinityModeratorMember since 2003
I have this problem also when I load the software for the first time slider only sits at 30% even though on the controller they’re both up at 100
This started to happen to me after the recent update .
geposted Sun 20 Oct 19 @ 12:11 pm
strange how you have to update 32-bit and 64-bit versions separately
As update now has been out for a few days but I hadn’t updated Oranda 32-bit version . I’ve just run the 32-bit version got the notification to do the update but I didn’t and the problem is not there . When I say update I mean early release update .
I have a feeling this is vector graphics issues the dimming issue and also flickering on text zones .
geposted Sun 20 Oct 19 @ 12:18 pm
Or the fader itself is going out which i just recently had happen and it acted just like your video.....
geposted Mon 21 Oct 19 @ 9:36 pm
