So let’s talk about them......
Any of you mobile guys here use them and if you do which ones are you using ?? How’s the over all sound?? Do these produce a lot of bass (I play a lot of bass music)??
Are there other speakers you’d rather go with??
Right now I’m using self powered JBL everything, four 15” tops and four 18” subs.
It all sounds great and I’m totally happy with them but can I get the same sound out of a line array system with a smaller footprint??
Thanks for the your time and any info you can provide.
geposted Mon 06 Jan 20 @ 3:36 pm
I use the Bose F1 system. Subs are static but the tops have an 8 speaker line array that can be curved to suit.
It's not a massively powerful system however it sounds gorgeous and does fine for all of my gigs. The bass is very very good and goes super low frequency.
The speaker curve does give better reach and it sounds very clear quite a distance away, but of course it also depends on the acoustics of the room.
There's no way it would compete with what you use but that would be overkill in the venues I work in, not to mention a major hassle to move about. The Bose easily fits in a Honda Civic with all of the other gear as well.
geposted Mon 06 Jan 20 @ 5:33 pm
Do you really mean line array speakers - like this:
....or do you mean those sticks that get called line arrays but are closer to column speakers?
geposted Mon 06 Jan 20 @ 6:04 pm
Yeah like these,
geposted Mon 06 Jan 20 @ 6:12 pm
Thanks Keith,
Yeah I was looking for something more portable but I don’t wanna sacrifice bass.
Guess I’ll probably stick with what I’m using then.
Thanks for the info
geposted Mon 06 Jan 20 @ 6:14 pm
Currently I'm using a couple of Turbosound IP3000 but I also carry two IP2000 for smaller events.
Can't be happier with all of them. They are punchy, easy to move and set-up and have a great sound overall.
geposted Mon 06 Jan 20 @ 7:33 pm
Hmm the SPL on those doesn’t look to bad, might have to find one and check it out in person.
geposted Mon 06 Jan 20 @ 9:11 pm
In My Opinion , there are no place for subtitution for a 12. 15 or 18 subs, because the frequency that can handle, from 35-100 Hz at certain power, you can use 10s , 8s even arrays of 3 or 4 inches drives for the highs and mids, and sounds great , and also is according of the size of the venue,
GK
GK
geposted Mon 06 Jan 20 @ 9:16 pm
Old school car guys use the phrase "There's no replacement for displacement." This is the equivalent of what you're saying.
geposted Tue 07 Jan 20 @ 9:30 pm
EV Evolve 50's is all you need ;-)
geposted Wed 08 Jan 20 @ 1:11 am
The SPL on those isn’t very high when compared to what I’m using now. That Turbosound has a higher Max SPL then the EV.
geposted Wed 08 Jan 20 @ 3:26 pm
You're never gonna get little sticks that have as much grunt as two pairs of "traditional" PA speakers like you've got. The physical difference is too great. They just won't move as much air.
Also it's best not to base everything off the max SPL figure. A lot of them are calculated/estimated from the 1W @ 1M dB figure. Chances are you'll never be able to run it that loud anyway.
Just to add a name to the mix, the FBT Vertus CLA 604A & CLA 208SA system is well regarded. Used by the likes of Denon DJ at their trade shows.
http://www.fbt.it/-/fbt-vertus-premiers-as-the-perfect-accompaniment-for-denon-dj-at-bpm
geposted Wed 08 Jan 20 @ 5:36 pm
Aah your probably right, I’ll just stick to what I have. Rather have to much then not enough. Plus it’s not like I use all 4 subs for every event. I’ve done some receptions where it’s just 2 tops and a sub.
Thanks guys
Thanks guys
geposted Wed 08 Jan 20 @ 8:16 pm
