Topic: Stem question
So i clean a lot of music for language is it possible to edit a stem, vocal in this case? Or can I export stem edit it in my daw and put it back as a VDJ stem?
geposted Mon 03 Aug 20 @ 10:16 pm
I think this (mute vocal stem) should be added to the Track Cleaner as an option for censoring. I posted in the wishes area already. Hopefully it gets noticed.
geposted Mon 03 Aug 20 @ 11:04 pm
I’ve been thinking about this and you could do it another way.
You could have a custom button with the following action:
toggle ‘cleanmix’
Then use the POI editor and add action POIs
var ‘cleanmix’ 1 ? mute_stem ‘vocal’ : nothing
You’d obviously need another action to return the vocals.
By doing this you’d only need 1 file. Have the button on for clean edits and off for dirty edits.
Practicality wise I’m not sure. But in theory it works. Just thinking out loud really.
geposted Mon 03 Aug 20 @ 11:45 pm
