Topic: 4channel mixer with timecode
So since stems has changed my life Im looking at 4channel mixers. My question with DVS can I just use 2 turntables to control 4 decks or does each deck need its own timecode signal to work properly?
geposted Tue 06 Oct 20 @ 3:31 am
I've never used DVS but i strongly assume that timecode is not "hot-swappable" which it would need to be if you wanted to change the deck one of your vinyl players is controlling. And even if it's technically possible, i wouldn't recommend it.
geposted Tue 06 Oct 20 @ 10:49 am
You can use invert_timecode for this
geposted Tue 06 Oct 20 @ 11:04 am
so that also can be mapped to the cue button on each Channel so along with cue it sets the timecode to that channel Im cueing??
geposted Tue 06 Oct 20 @ 12:54 pm
Im using denon sc3900s can you please cover more info for me. Because I plan on buying a 4channel dvs mixer. so before I spend the money I need to know the pros and cons, does it make better workflow buying 2 more decks? Im looking at the, from the most looked to the least, 1. mixars quattro, 2. Denon x1600/1700,
I have a Vestax vci4000 could that be used nut Im sure Ill need a dvs soundcard for that to work. I was also thinking about a 4 channel dvs controller. what would be the best configuration?
geposted Tue 10 Nov 20 @ 8:56 pm
As long as the mixer in question allows you to map the "CUE" (PFL) button, yes, it's possible.
geposted Wed 11 Nov 20 @ 1:49 pm
Phantom my biggest concern is when invert_timecode what it happen to the deck its coming off? Like deck 1 and 2 are in a blend when i hit pfl on line 3 and the timecode switches to deck 3 does it have any effect on the playing of deck 1 that it was switched from? I hope you understand my question?
geposted Thu 12 Nov 20 @ 6:33 am
xxx919, I have used the VCI- 400 w/timecodes as well - it should do the trick (as long as you have an external soundcard).
Not sure about inverting timecodes though.
I now use a Numark NS6II with timecodes and it works like a charm
geposted Thu 12 Nov 20 @ 3:18 pm
As soon as you use the "invert_timecode" action, the deck that "loses" the timecode mode is simply left alone (running on current pitch e.t.c.)
geposted Thu 12 Nov 20 @ 10:14 pm
Will this mixer or even the x1700 be able to handle usingthe cues to invert_timecode in the ways we were explaining....
geposted Sat 28 Nov 20 @ 12:13 am
wynderPRO InfinityMember since 2013
Rather than start a new thread I have a "similar" question here.
I recently saw that it's possible to use to 1x DVS turntable/cdj to mix flipping between an active physical deck & a virtual deck by copying the playing track & dropping the physical track to digital
Is this the same invert button mentioned above & with a a mixer that is pretty old & not mappable or even midi compatible, with an SL4 or an A6 dvs set up is this doable?
geposted Sun 29 Nov 20 @ 11:42 pm
As long as the cues send/receive a midi signal, yes. Yes it should work.
geposted Mon 30 Nov 20 @ 1:02 am
the SOUND INSURGENT wrote :
As long as the cues send/receive a midi signal, yes. Yes, it should work.
So I'm really a dummy when it comes to information like this....but this I think is the info so does this say cues send and receive midi?
geposted Mon 30 Nov 20 @ 4:38 am
Yup I see the send/receive commands there so your good 👌🏾
geposted Mon 30 Nov 20 @ 5:14 pm
Thank you...I hope after all my device switching they don't remove stems as a feature...lol
Stems are the only reason I'm moving to 4channel mixing...All those mixes and blend Ideas I had in the 80s and 90s are so doable now,
geposted Mon 30 Nov 20 @ 7:24 pm
geposted Tue 01 Dec 20 @ 3:28 am
