So I have a vci400, voxoa m70, 2 denon 3900s.
I thinking on replacing the M70 with the vci400 as the mixer for better control of 4 decks. Plus I'm gonna incorporate an Akai apc40 for stem controls.
My question is can I use a USB hub and how would I use it? Which devices do I connect.? I know it has to be powered.
geposted Sat 06 Feb 21 @ 10:14 pm
What about USB express cards?
geposted Sun 07 Feb 21 @ 3:02 am
You can use a hub for whatever you want.
I’d personally plug whatever soundcard your using directly into the laptop tho.
geposted Sun 07 Feb 21 @ 9:33 pm
Well got my new laptop and have connected everything but it's not working how I imagined. Can someone help, I think it's in the mapping.
I have 2 denon sc3900s and a vci 400.
How I want it to work the 3900s will be decks 1 and 2. The vci400 decks control decks 3 and 4. I've set the vci400 deck switches to c and d. But things aren't working. The deck buttons don't work. But I can move the job wheel and it will scrub on decks 3 and 4. But the play buttons don't work. The performance pads aren't working.
So how can I get this working correctly?
geposted Sun 14 Feb 21 @ 6:49 pm
