Hello, can I make it so that, in the search always, from the top there are tracks that I often play, without using the new filter button? So it was in version 7, and it is very convenient for me , in version 8 I spend a lot of time to find the right track (((, I scanned my entire database, on version 7, I find the right track in e second, on version 8, it takes 10-15 seconds, and I have to click either the filter button or return to the playlist, it is very not convenient((((
video my problem https://disk.yandex.ru/i/nQHcip0f8EloUA
I want that always from any folder, when searching on top there were tracks that I often play, as it was in version 7
geposted Tue 01 Jun 21 @ 5:48 pm
2 video my problem https://disk.yandex.ru/i/fWwNF0-QqFcdig
geposted Tue 01 Jun 21 @ 5:50 pm
its the default "sort" also in modern VirtualDJ.
But if you have other sort active (for example bpm), this will be the order...
You can always right-click any column header and choose to show play count and be able to sort that way manually. Or just click the small square at far left column header (over the file icons)
geposted Tue 01 Jun 21 @ 5:58 pm
No brother ,it doesn't work, if it was that simple, the support service couldn't solve my problem![](/img/337231/91483/est.jpg)
![](/img/337232/23855/net.jpg)
geposted Tue 01 Jun 21 @ 6:12 pm
I want that always when searching, on top there were files that I often use, without pressing extra buttons, as it was in version 7, once configured and forgot about it, in version 8, I have to do everything manually and for a long time (((
geposted Tue 01 Jun 21 @ 6:44 pm
setting keepSortOrder yes
geposted Tue 01 Jun 21 @ 6:48 pm
locodog wrote :
yessetting keepSortOrder yes
geposted Tue 01 Jun 21 @ 6:57 pm
locodog wrote :
I talked to support for a long time today, they recognized the problem, they could not help me (((setting keepSortOrder yes
geposted Tue 01 Jun 21 @ 7:00 pm
can we see a screenshot of your "search" settings, something like this
![](/img/337235/90553/search.png)
geposted Tue 01 Jun 21 @ 7:05 pm
![](/img/337236/32431/search.jpg)
geposted Tue 01 Jun 21 @ 7:09 pm
searchInFolder yes
searchByFirstLetter no
geposted Tue 01 Jun 21 @ 7:10 pm
locodog wrote :
searchInFolder yes
nothing has changed(((
geposted Tue 01 Jun 21 @ 7:16 pm
locodog wrote :
searchInFolder yes
![](/img/337237/54573/есть 1.jpg)
![](/img/337238/97604/нет 2.jpg)
geposted Tue 01 Jun 21 @ 7:26 pm
please copy and paste your browserSort setting here
this is mine [it won't work for you, I want to see yours]
file=Bpm|file(samp)=Title|file(sbnk)=-|file(ask)=-When|file(hist)=Play Time|file(karh)=Play Time|side(auto)=Original Sort Order|side=Artist|side(kara)=Original Sort Order|file(play)=Title|side(play)=Original Sort Order
geposted Tue 01 Jun 21 @ 7:27 pm
my sort file=-Play Count|file(hist)=Время воспроизведения|file(ask)=Исходный порядок сортировки|file(samp)=Исходный порядок сортировки|file(sbnk)=Исходный порядок сортировки|file(play)=Original Sort Order
geposted Tue 01 Jun 21 @ 7:33 pm
Try this.
file=Play Count|file(hist)=Play Count|file(ask)=Исходный порядок сортировки|file(samp)=Исходный порядок сортировки|file(sbnk)=Исходный порядок сортировки|file(play)=Play Count
geposted Tue 01 Jun 21 @ 7:37 pm
locodog wrote :
Try this.
The same thing (((
geposted Tue 01 Jun 21 @ 7:43 pm
It's working fine for me - if I understand correctly what you want to do
geposted Tue 01 Jun 21 @ 7:44 pm
