Virtual DJ and ns711
When using stems and it stop working
How do you reset without restarting virtual or the controller
geposted Fri 05 Nov 21 @ 7:58 pm
The problem is "Stops working" that should be your focus.
geposted Fri 05 Nov 21 @ 8:40 pm
I'm having the same problem. The stems stop working. Evening after rolling back to previous build.
geposted Mon 08 Nov 21 @ 4:26 am
possible that your machime needs to have a more power and higher specs. i have ns7ii and stems is ok on my end.
geposted Mon 08 Nov 21 @ 2:44 pm
Does this look like a machine that need more power. I have two hard in this computer... both m.2, one 500G and the other 2TB. RAM 32G, Intel(R) Core(TM) i7-10870H CPU @ 2.20GHz 2.21 GHz 64bit.
geposted Thu 11 Nov 21 @ 3:03 am
I found the problem... Th e MathEngine was disable after the last update.
geposted Thu 11 Nov 21 @ 3:28 am
