Topic: Program crash
The program is freezing during playback, I have a new laptop and using the Gemini G4 controller. I uninstall the program and did a clean install but has not fixed the problem, I also updated the drivers on the G4.
geposted Mon 27 Dec 21 @ 1:34 am
[quote=user15734285]The program is freezing during playback, I have a new laptop and using the Gemini G4 controller. I uninstall the settings and reopened. Problem fixed
Im havin same probkom. It will freeze on songs for bout 4 secs then carry on
Freezing of Skin and/or Audio?
i had the same problem , with audio and video
Could you give a description of the computer (pc/apple, cpu, gpu, ...) used when it appeared?
